oil pressure
Old Jan 29, 2006 | 04:48 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
oil pressure
what is the oil pressure suppossed to befor a 2.8-3.1, while ther car is at idle? i think the gauge in my car is broken.
Old Jan 29, 2006 | 05:21 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I show 60-80 PSI
Old Jan 29, 2006 | 05:47 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Originally posted by FAST RS
I show 60-80 PSI
Little on the high side there
I think normal, warm idle, is 20-50 or so... But yeah the gauges go bad very often so check it against a reliable one....can always rig up a manual sending gauge with an actual oil line just to check.
Old Jan 29, 2006 | 05:54 PM
FAST RS's Avatar
Mine has been like that since i hit my oil pan in a dip in the road about 5 years ago.
Old Jan 29, 2006 | 06:29 PM
well
i have a 3.1 in a 87 rx-7, so i think the gauge is bad, i have a electric gauge that will work off of the same sending unit, so ill try that
Old Jan 29, 2006 | 06:47 PM
FoxRodder's Avatar
Car: Fox Body+Third Gen Cam
Engine: a few
Transmission: few more
I just went through a thing on this car since I've only had it shortly. I was taking care of its cooling problems and was running it at idle showing like somewhere between 40 and 80....and then one time after running about 15 minutes I look at the gauge and notice its sitting on 0
I tried again with same results. After a little running would goto 0. With the advice of another member that I should just get the cheapie 5-10$ mechanical oil press gauge at walmart I was showing 50 and then once warmed and idle slowed down significantly around 20.
I changed out my sending unit with one from get in the zone auto zone and now its showing what should be 50 and when idle slows down sometimes goes to 20ish. It kind of worries me so I check it alot but I dont seem to be having any probs.
Old Jan 29, 2006 | 10:21 PM
thanks
thanks im going to get new gauge and then ill let you guys know.
Old Jan 31, 2006 | 02:48 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
before you get a new guage you might also want to take a look at the sender unit. It's usually cheaper than a guage and easier to replace.
Old Jan 31, 2006 | 02:53 PM
figured it out
my gauges in the car did the same thing, i got another gauge, and it runs just like foxrodder's thanks guys, you all helped me figure this out.thanks
Old Feb 1, 2006 | 09:23 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Mine sits around 20 at idle, and runs 40 cruising.
Old Feb 2, 2006 | 02:47 PM
daves12secV6's Avatar
u shoudl get 60 or above at idle on a cold start, once the engine warms up u should get a 15-25, and while crusing 40-50 psi, if ur oil presure is below 15 at idle id begin to worry, though what wieght oil u use will make ur oil pres vary
i happen to run 50 wieght in the summer and 20-40 wieght in the fall/winter
Old Feb 2, 2006 | 03:05 PM
oil?
um well here in houston it gets really hot, so i run 10/30. and if it was to get cold i would go to 5/30
Old Feb 2, 2006 | 03:47 PM
im in new jersey so in the summer its like 90+ out and in the winter its like in the 30's. i swear by the 50 wieght stuf fin the summer. ive had engines with 50,000 + miles on them that ive used 50 wieght in and they looked brand new on the insides
Old Feb 2, 2006 | 04:50 PM
thanks
im actually going to be replacing my engine soon, so ill keep that in mind when the new engine goes in. it had 5/30 in it, when i bought it, so i just wanted to thiken it up a little, so it wouldnt make as much noise. but thanks.
Old Feb 2, 2006 | 08:07 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
good lord that is some thick oil to run all the time.
Old Feb 3, 2006 | 02:00 AM
viscosity
for sure.....
Old Feb 3, 2006 | 04:53 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
DITTO
runnin 20W50 year round.
TomP said his car would hit 0 at idle. year or two back.
Old Feb 7, 2006 | 04:02 AM
ok ok
great, now my gauge reads circa 50 when cold, then drops around 20-30. then after like20 mins of driving around the gauge drops to 0. but if i restart the car it works again? is my gauge just crazy? i have no idea.
Old Feb 7, 2006 | 08:57 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
if your using the stock rx7 sender and gauge it's bound to be all messed up
I drive my rx7 on 0 psi oil pressure all the time :-)
and before I aws driving it on 120-130psi of oil pressure AT IDLE!!!!
there is no way to be sure how accurate that thing is
but might I ask WHY A 3.1 in a rx7?
Old Feb 7, 2006 | 09:42 AM
well its the rx-7 gauge, but its the chevy sending unit. i didnt put the engine in it, i bought it from a friend, who's dad put it in there. probobly because it was cheaper than buying another 13b. i dont know. im just trying to work out all the bugs, the wiring is good, the engines good. the trannys a little wierd, but nothing that cant fixed. plus i want to swap in the 3.4, and turbo it.
Old Feb 7, 2006 | 12:11 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
the only other possible thing I would worry about is what is the resistance reading of the stock gauge vs the chevy sending unit.
sometiems the two might not be compatible and give bad readings
Old Feb 7, 2006 | 02:52 PM
FoxRodder's Avatar
Engine: a few
Like I mentioned by old bad sending unit was doing the go down to 0 thing after warming up and if I restarted car it would work again.
My old sending unit had oil coming through to the electrical plug because I guess the internals wore out. The new one was sealed up tight with silicone or similar. Make sure yours isnt leaking anywhere. Even if the gauge is not the right one if it shows pressure then goes to 0 for no reason it eliminates the gauge I think.
Old Feb 7, 2006 | 03:00 PM
Thunderfest's Avatar
You guys know that the factory specs on these engines say they sould always operate between 30 @ idle and 55psi revving?
Some of you have worn motors and I would not recommend revving very high if you pumps are worn and not producing the proper psi.
Old Feb 7, 2006 | 03:08 PM
FoxRodder's Avatar
Engine: a few
If we get 45-50 psi at most anything above idle why would high revving be a problem?
Old Feb 7, 2006 | 08:15 PM
Doward and Gumby both stated they are getting 20 @ idle and 40 cruising- Thats low.
When the motor is revving higher the oil is flinging off the jouinals quicker and can starve from lack of lubrication if you are not getting adequate oil pressure. 40 is low even for cruising on these motors, but not for a SBC V8 since they have different lubrication paths.
Old Feb 7, 2006 | 08:29 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
pressure doesn't always equate to flow
so having a lower oil pressure doesn't mean the flow isn't there to lubricate the bearings
at times having a lower oil pressure might actually mean MORE flow. even more so being that pressure is a resistance to the flow.
Old Feb 7, 2006 | 08:39 PM
I will agree with everything you said- However, we are not talking aftermartket setups. We are talking about a specific factory pump with specific size gallies that require about 50-55psi for that combo to get adequate flow.
Old Feb 7, 2006 | 10:50 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
I'm not talking aftermarket setups either
it's just like your stock fuel injectors. you up the pressure on the regulator your total flow through the injectors tends to become less. well when considering max output.
if the thingy that is supposed to regulate oil pressure decides not to work correctly and instead go mostly open your total pressure should drop but your oil flow should go up.
Old Feb 7, 2006 | 11:11 PM
yeah but u can have all the flow u want without oil presure the bearings will make contact with the crank
Old Feb 8, 2006 | 12:13 AM
First of all, this is Dean you are talking to just so you know.
Secondly, you can not equate a fuel system pressure with an oil system pressure- they are monitored differently. A fuel system is monitored at the rails *before* the injector spray and the regulator relieves the excessive fuel pressure back to the tank- The oil system monitors the pressure long after the source and is what registers the flow- to equate the fuel and oil is to try and measure the psi of fuel *after* the injector spray.
And you are backwards on the fuel pressure to injector spray- How in the world can you say that flow goes down through injectors when the fuel pressure is turned up- you need to do some reading my friend
Old Feb 8, 2006 | 12:25 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
My oil pressure is at about 60 at start up. Once it warms up it drops to around 40. It only went to 80 when the sending unit was bad....and only went to 0 the times I ran out of oil in a turn because of a VERY nasty leak I had/have
.....buuuttt I will say, I'm surprised the thing is still going. Ran on 0 quite a few times and has no problems.......I'm guessing the car WANTS it's original 2.8 and not a 3.4?
Old Feb 8, 2006 | 07:41 AM
FoxRodder's Avatar
Engine: a few
Well from what I keep reading on the forums these motors have been known to go many many miles. If the oil pressure is suffering a little bit and it keeps rolling for a long time I'd be fine with that. I hardly ever rev the motor out anyways since it aint a race car. I've done it like once so far just to see what it would do(not a whole lot )
I also decided to run 10-40 when I first got it because of the 0 pressure problem just in case the oil pump needed some help. I may get good or bad responses on that issue.
Old Feb 8, 2006 | 09:15 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
flow through the injectors might go up but then again it also it is a little limiting in a way as well. I know what I'm trying to say but I can't think of how to phrase it. but basicly I think it is somethign along the lines of once flow startsto go up it can't keep up the the pressure or something. as I said I know what I want but I can't put it through right. I keep thinking of it like electronics high resistance source can not handle much current draw before teh voltage drops fairly low compared to to at idle current.
as far as where the fuel pressure is monitored I agree a little that where the meter is placed can have a difference but I'm sure you understand what I was trying to get at.
put a pressure meter in your exhuast. shove a cork up your tail pipe and cut a 1/2 inch hole through the cork. flow goes down pressure goes up
and you just never give up with this place do you :-)
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
