my car is dead
Old Feb 8, 2006 | 08:34 PM
daves12secV6's Avatar
my car is dead
well im not sure really but im hoping i only broke a lifter or rocker arm/or possibly wiped a ex side lobe on my cam.
was racing a golf vr6 gti from a light first gear was fine shifted at 7,400, and as im comming up threw second at about 6,800 rpms the motor got real ruff by the time i got off the gas at 7,100 it sounded like a loud *** tap like a lifter colapsed.reason i think it is something in the valve train is my air fuel gauge was bouncing along with the taps in the engine. well ill find out for sure tom when i get to work ima get the car inside and pull the valve covers and take a look
Old Feb 8, 2006 | 08:53 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
goodluck, dude. mine did something similar to that back in may...i think it was a piston ring that busted (still haven't torn into it that far cause it still runs; pulled the heads but not the crank/pistons). i didn't look at the a/f guage when it happened but i was up probably over 6k rpms, too. let us know what you find, though.
Old Feb 8, 2006 | 08:59 PM
sshh dont jinx me, lol it very well could be a pistion. bu8t the way the motor was acting its liek its not opening one of the ex valves im 85% sure it was something in the valve train. But ill know for sure tom
Old Feb 9, 2006 | 10:40 AM
well i got into the motor today looks liek the only damge is a bad lifter, got a new set comming overnight delivery,so ill know for sure tom weather or not i hurt anything else
Old Feb 9, 2006 | 03:36 PM
Car: 91 Camaro
cool. hopefully that's all it is.
Old Feb 9, 2006 | 05:22 PM
well if its more then just that im going to drop in the 358 sb motor, ahead of schedual, which is gonna suck cause i wanted to get the car painted before i did the swap, but if thats all thats wrong with it.Im serously debating on droping in some dished pistions and building a custom turbo kit , and saving the 358 for the drag only camaro im building, though im sure when tha done it will see some street time lmao
Old Feb 10, 2006 | 02:53 PM
woot its fixed got the lifters in and the motor buttoned back up and it runs fine
Old Feb 10, 2006 | 03:11 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
good to hear that cars are back on the road.
Old Feb 10, 2006 | 04:29 PM
yeah im glad it wasnt blown up to badly, i wanted a shot at breaking low 14,s with the 2.8 this march, but i may be buying another rs so if i do im gonna leave this one with the 2.8 and turbo it ontop of whats already done to it
Old Feb 10, 2006 | 05:46 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
did you just mill the heads to get to your compression? or did you do a piston swap?
Old Feb 10, 2006 | 09:29 PM
Car: 91 Camaro
awesome, i wish i had been that lucky on mine!
Old Feb 10, 2006 | 09:37 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Racin like that, ya should of got some fast leak down lifters for it.
Linson
Aug 21, 2015 02:12 PM
justin57
Aug 20, 2015 07:05 PM
Irocohio
Aug 12, 2015 08:03 AM
hokis
Aug 9, 2015 03:57 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
