Increasing Gas Milage
Old Feb 8, 2006 | 09:34 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
ok .. Im wondering what you guys have done to increase the gas milage you get with ur 2.8 V6's.. Gas prices here just tipped $2.50 a gal for 87 Octane.. Ouch..
Old Feb 8, 2006 | 09:37 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
tune up
87 has been over 2.50 a gal for a while up in my area.... i dont think it even went bellow 2.50.. though i use 89 :P
Old Feb 8, 2006 | 09:41 PM
daves12secV6's Avatar
lmao i think my rs barley gets better milage then my 2 irocs
Old Feb 8, 2006 | 09:52 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
im getting about 180ish miles out of a tank (fill up right at 1/4 of a tank i useally never allow it to get below the 1/4 mark)... do a tune up. make sure your tires are correctly inflated (right PSI) and if you have a carb on the car (like me :P) make sure the carb is adjusted correctly and make sur ethe car isnt running rich...
Old Feb 8, 2006 | 10:59 PM
that must suck 87 is like 2.05 here 2.25 for super
Old Feb 8, 2006 | 11:13 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
it "sucks" the wallet dry stupid Cali....
Old Feb 9, 2006 | 12:53 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Put a crank power pully on "underdrive pully" it will increase your MPG.
Old Feb 9, 2006 | 01:11 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
once i did a full tuneup on my 2.8 it got 23MPG city. around 30+ if i did a whole tank highway. oh my car has an aftermarket cam shaft in it. i don't know anything about it though. prioir owner did it.
Old Feb 9, 2006 | 05:33 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
if your iac was going bad would that effect gas mileage ive done a complete tune up everything possible except changing the iac and putting the fuel filter thats in my closet on. If it does effect gas mileage how much better mileage should i see with the new fuel filter and iac on
Old Feb 9, 2006 | 05:44 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
The IAC doesn't normally affect performace or milage as long as it's working properly. I wouldn't expect any gain out of it.
Did you change the O2 sensor, that's a big thing that people miss on their tune-ups.
My car gets right around 24mpg with a mix of both city and freeway driving, and the freeways here in L.A. are almost like getting city milage anyway during rush hour.
No remember that's with a manual transmission car, autos get slightly less. The O2 I have must be 3 years old at least just because I'm too lazy to change it. I think I might go do that right now...
Old Feb 9, 2006 | 06:50 PM
Pocket's Avatar
Car: 91 Trans Am
Fuel filter- single best thing you can do to save gas
My 2.8 5 spd peaked 25 mpg HW
My 5.0TBI A4 peaks 32 mpg HW with the 2.73 rear
227,000 original miles, no mods has its benifits
Ive got a mystery vaccuum leak thats dropped me to 28-9ish HW and made my idle rough, currently
Old Feb 9, 2006 | 07:01 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
yes i changed the o2 sensor with a bosch one.
Old Feb 9, 2006 | 08:55 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
hmmm.....gas is about $2.82 or so for REGULAR down here!
You can get better gas mileage by not using the A/C.....IMO only 3rd gens should be driven with the window down cause they just look sooooooooooo cool with the driver's elbow sticking out the wondow!
Old Feb 9, 2006 | 08:58 PM
madathlon's Avatar
I got mine becouse of the AC.. It gets hell a hot here in the summer
Old Feb 9, 2006 | 08:59 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
I have the components for the a/c. .but the a/c only lasts for a week after i get it charged.... no freakin clue why though *sighs*
Old Feb 9, 2006 | 09:00 PM
madathlon's Avatar
Thats sux.. It be time to have it checked out by a pro than..
Old Feb 9, 2006 | 09:04 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
ive already had it looked at.. Even the pro's cant figure out whats wrong with my ac..... so i got my two 65 fans.. (both windows down doin 65 on the highway... hot air but it is still movin :P) I need tint....
Old Feb 9, 2006 | 09:10 PM
1989karr's Avatar
Engine: 3.4 / 5.0
maybe you have a leak in the evaporatr/condenson? Did they put dye in the system?
Old Feb 9, 2006 | 09:18 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Yea.. dye was put in, they didnt spot any leaks... the next thing im going to do when i get the cash it to replace EVERYTHING that relates to the a/c system (compressor/acculator/condenser/ect ect) and then have it recharged.. im begining to think that when i had the system converted over to the new freon or what ever they call it now, the shop screwed up my system.. i know i had a low pressure side connection that was striped all to hell by them (a/c filter tube).... at this point in time. .i just want to figure out why my rpm's shoot up to 3000rpms when i turn on the heater on the defrost setting..
Old Feb 9, 2006 | 09:36 PM
1989karr's Avatar
Engine: 3.4 / 5.0
hmmm...I know that when my A/C died (I think my compressor is seizing up again though ) the RPMs would go up higher because it's supposed to when the compressor engages. But I was so low on freon the compressor didn't engage so the RPMs just went up without the compressor load compensating for it. I don't think they went up to 3,000 though.
Old Feb 9, 2006 | 09:39 PM
madathlon's Avatar
ok.. where would I find a underdrive pully and a part # would be helpful
Old Feb 12, 2006 | 03:16 PM
fishboy's Avatar
Car: 88 firebird
Engine: 3.1
Transmission: Stock-auto
Hey for the underdrive pulley, check ASP
http://www.aspracing.com/frame.htm
Old Feb 12, 2006 | 04:38 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
When my car is running right, I easly get 200 per tank all in town. I dont trust the gauge so I always fill up around 200.
I know on the interstate, my x got 29.x mpg out of it. I never could. My best was around 27 interstate.
87oct friday was 2.19 here.
Old Feb 22, 2006 | 12:42 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
PUF! Dont' cry about this.
I pay $ 4.07 per 97 octane here.
Local 1 liter = CH$ 564 @ CH$ 527/ US$ 1 = US$ 1.07 per liter x 3.8 = US$ 4.07 per gallon.
What do you think about this?
Regards,
Denis V.:
Old Feb 22, 2006 | 02:34 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
my ***^ i couldnt afford that. i hate having to spend 2.39 a gallon here.
Old Feb 22, 2006 | 02:50 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Regards,
Denis V.:
Thats how them oil companis are showing record profits. That scam they worked up called the metric system, is working.
no way they could ever pull that liter crap in the US.
We'd burn the places down and make poo fuel.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
92firebirdguy
Sep 1, 2016 07:53 AM
tonys91rs
Oct 10, 2015 03:31 PM
kx3g
Sep 28, 2015 08:14 AM
