custom chips
Old Feb 27, 2006 | 12:17 PM
daves12secV6's Avatar
custom chips
hey any u guys happen to have the right bins and **** for the 2.8 engines i cant sem to find the right ones.
Old Feb 27, 2006 | 02:11 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
yah, ive got a couple. for the MAF systems i only have auto bins, two are listed as 86 and the other 87. pretty soon ill be able to scan in an 89 auto and 89 manual, but that could easily be postponed indefinitly. i can e-mail them to anyone that wants, or you can search through the muck at http://www.diy-efi.org/gmecm/
Old Feb 27, 2006 | 06:09 PM
naft can u email me the bins for the 87 2.8 auto think it will work for an 89 auto car ? Lethalrides2k5@yahoo.co.uk
Old Feb 27, 2006 | 07:14 PM
Naft's Avatar
it should work, you might have to bypass VATS though.
Old Feb 27, 2006 | 08:22 PM
thnx man got the bin.now i can compare it to the chip that my friend did for me.im gonan need it anyway once i drop back to stock cam for the turbo
Old Feb 27, 2006 | 08:43 PM
hey man that bin wasnt messed with was it some settings dont seem right at all like rev limits fuel cutoffs a/f ratio
Old Feb 27, 2006 | 08:54 PM
http://2wai.ics-il.com/2.8.txt
Old Feb 27, 2006 | 11:02 PM
Naft's Avatar
i didnt modify it, thats about all i can testify to.
are you using the $6E mask? that .txt file says $6E.xdf, but you should be using $3A.xdf. the LB8 motors use a different mask than the V8 TPI's.
I pulled this from the .txt file
Code:
Speed Limiter - Stop Fuel                                        23.00 MPH
Speed Limiter - Re-start Fuel                                    58.00 MPH
Rev Limit - Stop Fuel                                            15.04 RPM
Rev Limit - Re-start Fuel                                       106.44 RPM
tell me that isnt horribly wrong!
Old Feb 27, 2006 | 11:33 PM
thats what i was reffering to btu opps yeah using the wrong file my bad agh whats the chance u ahve the right definition file? or a link to it
nm found it
Old Feb 28, 2006 | 12:31 AM
jebesus this isnt gonan be easy looks liek tuning with fmu and wide band o2 and msd btm will be easier, wa slooking at the maf maps and once i hit the last table it is maxed already
ramicio
Sep 28, 2015 01:18 PM
Deemax
Sep 12, 2015 06:53 PM
Ranbo108
Sep 9, 2015 12:20 PM
TBRays98
Sep 6, 2015 05:05 PM
