idle RPMs
Old Feb 27, 2006 | 05:38 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
idle RPMs
What should the idle rpms be on a 88 2.8 MPFI with A/T.. I have a chiltons book but it doesnt say what the idle RPM should be for the 2.8...
Old Feb 27, 2006 | 05:47 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Hmm.. mine says 500Rpm for manual & Auto is supposed to be 600Rpm. hope that helps.
Old Feb 27, 2006 | 06:06 PM
madathlon's Avatar
well thats a problm. it wont run below 800rpms.. and its sounds really sick at that ... Sounds good and idles great at 850 to 900
Old Feb 27, 2006 | 06:19 PM
xplane's Avatar
Engine: 2.8 MFI
Mine idles smoothly with a bit of chop but very little rpm jump. its just the cam mine has. if it wont run that slow it has a vac or IAC passage/motor problem. mine runs 550-600. idles at 1000 till it warms then settles down to that idle.
Old Feb 27, 2006 | 06:59 PM
madathlon's Avatar
I rebuilt that top half chasing Vac leaks today.. would the IAC give a code if it went bad?
Old Feb 27, 2006 | 10:06 PM
xplane's Avatar
Engine: 2.8 MFI
hmm not shure. it should but i have had the ECU fail to tell me something was bad even after it stoped working so i cant say for shure. also stock or aftermarket tach? if aftermarket how is it wired in? wire from the coil or clip on the #1 spark wire?
Old Feb 27, 2006 | 10:20 PM
daves12secV6's Avatar
before i did the cam and **** my cold idle was 1,300 and warm idle was around 800-900 if that helpslol now my idle is like 450-700 lopey and very rough due to the large cam
Old Feb 27, 2006 | 10:37 PM
madathlon's Avatar
800 - 900 makes more sense.. trying to make it idle at 450 -550 and the oil pressure drop to just about nothing.. ( about 15 - 20 psi ) and keeping it running is almost impossable.. Is there a way to check the IAC unit if its working? the books only says how to remove and replace.. but not how to check.. I did find out that my ECM does not check to see if the IAC is working...
Old Feb 27, 2006 | 10:49 PM
xplane's Avatar
Engine: 2.8 MFI
thats what mine runs.
Old Feb 27, 2006 | 10:51 PM
xplane's Avatar
Engine: 2.8 MFI
well 550 is what mine runs. WTF? how did that happen? 2 at once?
Old Feb 27, 2006 | 11:00 PM
pull the iac and see if theres any dirt or anything built up in it
15-20 psi at idle warm is ok check that ur tps is adjusted right also that can mess up ur idle also
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
