Started my build...
Old Mar 5, 2006 | 05:59 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Started my build...
Well I just got home not too long ago with my new/used 2.8 V6 long block... Ive already got the heads ready to come off and will soon be going out to get Ported & Polished... Before they go out Im gonna see if i can use the drivers side exhaust manifold upsidedown on the passenger side for my turbo manifold... I checked it out first with gaskets and everything looks like itll bolt up.. Only problem will be clearance but I dont think anything will be in the way.. I still have to buy a rebuild kit and get ahold of some 3.1 internals to throw in there instead of the 2.8's... I got my hole drilled in the oil pan for the return line from the turbo but I still have to weld on a fitting... I also bought some aluminum pipe to fab up some fuel rails for my custom intake... Everything seems to be coming along great and I hope to have the engine in my Camaro by the end of April... Pics will come as soon as I get another battery for my digital camera..
Old Mar 5, 2006 | 06:52 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
Re: Started my build...
brilliant
beats paying 400+ for a custom fabricated exhaust manifold.
Old Mar 5, 2006 | 07:14 PM
Yeaa it does beat payin money...
Old Mar 6, 2006 | 09:49 AM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
dang it, everyone's getting their build started and i have to wait until april or maybe august
good luck! what exactly are your plans?
Old Mar 6, 2006 | 11:24 AM
Well the heads are gonna be completely ported n polished.. gonna get a bigger cam.. better timing chain.. hopefully sbc rods.. gonna get the lower intake ported.. stiffer valve springs so the valves dont float.. prolly get it bored .010 over.. custom plenum and TPI throttle body.. T3/T4 turbo.. ported exhaust manifolds.. thats it I think.. Along with a rebuild kit of course..
Old Mar 19, 2006 | 04:09 PM
Well I found a 3.1 stroker kit for my 2.8... its about $500 and Im gonna get the pistons oversized.. Not sure what size yet but its looking towards .040... I should have some pics up by the end of the week of the engine thus far along with my turbo and manifold... Intercooler should be arriving next week its a 28x10x3.. Also got a Turbo XS type H BOV that will be here shortly.. I found a cam that I want but Im not sure if itll be compatible with my setup... Ill prolly send out the heads next week..
Old Mar 19, 2006 | 04:12 PM
daves12secV6's Avatar
hey heres a link for s stroker crank reman with bearings
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MEWA:IT
it ends in about 1 hour 55 starting bid or 75 buy it now
Old Mar 19, 2006 | 04:16 PM
Im gettin everything with that kit.. rods, crank pistons to whatever size I want.. rings, bearings... Id rather buy it all together than in peices anyways.. thanks for the heads up tho
Old Mar 19, 2006 | 04:17 PM
ahh ok,gigured if ya picked that crank up u could buy the pistion seperatly,use old rods(since there the same) and still cost less
Old Mar 19, 2006 | 04:26 PM
Naft's Avatar
yah thats a screaming deal for crank + main bearings
pistons + premium rings + rod bearings ~$300-350, so if you dont really care about the new rods you would come out a good $100 on top. but if you want the rods the kit is a decent deal anyway, so go for it.
Old Mar 21, 2006 | 08:06 PM
Well I just pulled some rails off a FWD 3.1 to use for my custom plenum... Got the injectors too.... Im gonna take my car to get dynoed this weekend to get a baseline.. lol Gotta fix my timing issues first.
Old Mar 21, 2006 | 08:08 PM
nice im gonna get the rs dynoed this weekend as well 50$ for 4 puls with wideband o2
Old Mar 21, 2006 | 08:15 PM
Nicee.. I bet you got more power than me lol
Old Mar 21, 2006 | 11:01 PM
i doubt it i took out my killer cam, and im back to pretty much stock computer tune, and below stock cr ratio
Old Mar 27, 2006 | 10:38 AM
Well the rails that I got off the FWD 3.1 are differant than ours.. The injectors are spaced alot differantly.. Im sending out about $700 worth of money orders today for all my parts.. I might have pics of my dissassembled engine later today..
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
happyhapka
Aug 15, 2015 04:42 PM
92camaroJoe
Aug 13, 2015 06:07 AM
