please help. anyone with a 2.8
Old Mar 10, 2006 | 05:10 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
I have three grooves on the harmonic balancer on my 2.8. which one do I use when i stab the distributor? I've set the number 2 piston at TDC, compression stroke up. I think I know where #1 is on the cap, look at my drawing and see if I am correct.
my buddies #1 on his 3.1, seems farther back. should mine be the same. I know all 6's use the firing order 123456 on the cap.
please help.
File Type: bmp
Old Mar 10, 2006 | 06:21 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
Why #2? Put #1 on TDC than set the Dizzy in and do the timing..
Old Mar 10, 2006 | 09:31 PM
micali's Avatar
Engine: 2.8
Sorry, I did number 1. Don't know what I was thinking.
Old Mar 22, 2006 | 08:28 PM
micali's Avatar
Engine: 2.8
actually I had it all mixed up. got it figure out though
Old Mar 22, 2006 | 08:39 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
As for which mark, find the biggest, I belive my s10 2.8 had 3 as well.
If you have access to another engine similar, set them both side by side and match the other. Then fine tune it with the est disconnected and a timing light.
Numbah-1
Oct 2, 2015 08:27 AM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
abrilnelson89
Sep 17, 2015 10:41 AM
abrilnelson89
Sep 16, 2015 02:19 PM
