eliminating VATS
Old Mar 26, 2006 | 09:00 AM
camarojunkie77's Avatar
Car: 1977 camaro z28
eliminating VATS
Have a 93 camaro with a 3.4 and it will run for a second then die.I just changed the fuel pump on my back in the garage and I think the vats is keeping it from running.I purchased the painless VATS module to eliminate it,but the module is for a lt1, and the picture for the computer diagram is different. Does any one know what wire coming out of the computer is for the the VATS. ANY HELP WOULD APPRECIATE!
Old Mar 26, 2006 | 09:48 AM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
VATS disengages your ignition, fuel system and starter. When VATS trips you get nothing, no starter click, nada. It wouldn't run for just a second, the starter wouldn't even engage.
Watch the "security" light. If it comes on for a second, then goes away, VATS is working. If it stays on, VATS is tripped.
Your problem might be the fuel pump relay under the hood almost directly in front of the driver on the firewall. Could also be the in-line fuel pump fuse. Sure sounds like a fuel delivery problem to me. Clogged fuel filter, clogged injectors etc would make that happen too.
Old Mar 26, 2006 | 10:25 AM
The security light is constantly on all the time and the car has run with it on.The car will drive perfectly then will just die and not start.Give it a couple of hours and it will start right up again.So it does sound like the fuel pump relay is getting hot and just shutting down.Allowing it to cool down a few hours might be the relay. Will change the relay first to see if that changes the problem.Thanks for the advice.By the way the filter was changed with the fuel pump.
Old Mar 26, 2006 | 11:07 AM
bobdole369's Avatar
Car: 1989 Firebird
fuel pump relay is a nice cheap fix. Relays are notorious for that. Good thing its nice and simple. I'd go that route first. As for security light, thats some problem you got, glad mine didn't do that and it was just a broken keyswitch wire LOL.
Old Mar 26, 2006 | 11:57 AM
Looked for the fuel pump relay in the relay box and did not see were the relay is at?Does any one know were it is at?
Old Mar 26, 2006 | 02:04 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
That's not a 3rd gen!
Old Mar 26, 2006 | 05:17 PM
bobdole369's Avatar
Car: 1989 Firebird
On a thirdgen its up on the firewall with 2 other relay almost directly in front of the driver. Not sure on your car.
Old Mar 26, 2006 | 05:35 PM
bru333's Avatar
Car: 1987 Camaro SC
Try this site : http://shbox.com/1/component_location_views.html
Old Mar 26, 2006 | 07:54 PM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
MAYBE THE IAC VALVE IT HAPPEND TO ME A WHILE AGO IT COST ABOUT $30 OR YOU CAN JUST CLEAN IT BUT I REPLACED IT
Pac J
May 17, 2020 10:44 AM
RS Reaper
Oct 17, 2018 07:52 PM
