Header bolt questions
Old Mar 27, 2006 | 06:14 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
So Im getting ready to install my headers and have a few questions that I couldnt find the answers to. First I read to soak the bolts in PB Blaster before removing them. I heard doing it 48-24-12 hours before helps a lot. My first question is, since this is a daily driver will the heat of the engine running burn it off and make the process useless? Next, I know I have 3 broken bolts. Say I cant get them out, has anyone just put a nut on the remaining threads? Would that be ok if I cant get 1 out? I see no problem but Ive never done this before. Thanks for any info.
Old Mar 27, 2006 | 06:19 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
yes running it will make using the PB Blast useless..And if cant get the bolts out.. take it to a machine shop to have them removed.. The bolts will not torque up right with just nuts on them.. ( Threads may not be deep enough in the block ) And if your driving it every day with 3 broken bolts, there a very good chance that you have warped the heads... And you will need to have them decked so they will make a good seal once back on..
Old Mar 27, 2006 | 06:53 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
definitly have the broken bolts removed. If you can't get a good seal, you'll have exhaust leaks. Believe me, they suck.
Old Mar 27, 2006 | 08:35 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Please explain the logic in that.
Old Mar 27, 2006 | 09:02 PM
madathlon's Avatar
Well driving around with 3 broken bolts( I'm assuming head bolts sense he didn't say other wise ) the head heats up and expands with = force spread across the bolt/studs ( depending on set up ) But if there a gap in the spread that not suppose to be there.. the expanding is than un= to The rest of the head.. and since the expands area cool at a different rate it will cause warpage.. And if You think I'm mistaking, than take it to a machine shop and see for yourself ( Or if U have a true straight edge you can test it your self.. )
I have over the years rebuilt Inboards and outboards.. And a common mistake I have seen for shade trees is thinking the other bolts will do the job by them selfs..
Old Mar 27, 2006 | 10:08 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
hmm...pretty sure (or 100% sure) he's talking about exhaust manifold bolts...not head bolts.
Old Mar 27, 2006 | 10:13 PM
madathlon's Avatar
Man.. Its been a long day.. Sorry.. My mistake.. Time for bed for me.. LOL
Old Mar 28, 2006 | 12:41 AM
Yeah that's why the warped head commenbt made no sense to me.
If there was three broken head bolts, he wouldn't be driving it around.
Old Mar 28, 2006 | 12:16 PM
grimmcs's Avatar
Car: 91 Camaro
Sorry I guess I should have been more specific with my wording. And the broken EXHAUST MANIFOLD BOLT () positions are, 2 on the #5 cylinder and top of #2 cylinder. So here is the problem, I dont want to pay $400 to have a guy put in my headers when I could do it myself. That, and I dont have $400 to throw around. So if I end up getting all of the bolts out but the three can I put a nut on those bolts to at least get me to the shop to have them drilled out?
Also will just putting the PB Blaster on the afternoon/night before do enough or will it need more time?
Old Mar 28, 2006 | 03:31 PM
Car: 91 Camaro
lol...its alright man, I've been there on the long day thing plenty of times.
As for the PB blaster deal, I say soak them then if you have to drive the car, go drive it...its not going to hurt anything. well, let me rephrase a little. I wouldn't go drive the car right away after spraying them down with blaster. But, if you spray them down after you get home from school or work or whatever (after letting everything cool of course) then drive the car the next morning, you're not going to hurt anything. It might smoke a little but nothing serious.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
