stock 3.4 cam on 1.6 rockers
Old Mar 29, 2006 | 10:05 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
any thoughts on using the stock 3.4 cam(.423/.423-Duration: 264°/274°
RPM Range: 1200-4600) with comp cams 1.6 roller tip magnum rockers, will that allow me to pull good to 5200-5500 ish? i think that puts me around a total of .4512 on both sides, and if i do go for a bigger cam, is it true i can retain some bottom end power with some of these lifters http://www.jegs.com/webapp/wcs/store...0213&langId=-1, or are any of those not going to fit my motor
Old Mar 30, 2006 | 08:16 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Don't worry about low end torque - our intake takes care of that (and kills the real screaming top end power )
Yeah, that would be fine - I might suggest using full roller rockers, though, unless you already have the roller tips
Old Mar 30, 2006 | 04:55 PM
Car: 1986 Firebird
what full rollers should i use, i know of the gold roller rockers, but they're so expensive, is the real gain in a roller rocker the roller pivot?
Old Mar 30, 2006 | 06:34 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
what else do you have done?
I went to roller TIPPED 1.6 rockers and noticed nothing. Simulation program showed peak 3 hp.
I personally feel you would get better bang for your buck on something else first.
Old Mar 30, 2006 | 08:31 PM
Car: 1986 Firebird
yea, now that you mention it, it would probably be better spent on dropzone springs and an
alignment
Old Mar 31, 2006 | 09:46 AM
Doward's Avatar
Yep dropzones + shocks + alignment made my car a WHOLE lot of fun real quick.
Better though, if you are still stuck on 15" rubber, get you some 16x8" wheels and some 245/50/16s. Nothing (well, the turbo ) has made as much of a difference to my car.
Otherwise, you can supposedly use any narrowbodied rockers... I'll have some pics next week of me reworking my heads, using ARP rocker studs to allow use of my Comp 1.6 full rollers.
midge54
Dec 27, 2019 04:14 PM
Cameeeero
Sep 18, 2015 04:00 PM
LT1Formula
Aug 20, 2015 09:36 PM
happyhapka
Aug 15, 2015 04:42 PM
