need help fast races tommorow
Old Apr 1, 2006 | 12:22 PM
91 v6's Avatar
Car: 2002 ranger(showtruck) 90 firebird
Engine: 3.1l
just left the house and right down the street the car died got it to start but idles really rough and wont make enough power to more the car. i havee the first race of the year tommorow and need to figure this out quick any help would be great thanks
Old Apr 1, 2006 | 01:39 PM
91 v6's Avatar
Engine: 3.1l
seems to do it when the engine is hot
Old Apr 1, 2006 | 06:19 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Check pickup coil, and ignition module, first.
Do you have spark? Fuel pressure good?
Old Apr 1, 2006 | 07:52 PM
91 v6's Avatar
Engine: 3.1l
at first it was when its hot or so i thought looked through the car and came up with this no engine codes, good spark, good fuel pres. this is my diagnosis, when i hit the gas and the car asks for more fuel, all its getting is air. changed the tps and now the car idles smooth(at 2000rpm) but when i hit the gas it bogs out to about 400 rpm or sometimes stalls. then revs back up to 2000 this sucks, im lost
Old Apr 1, 2006 | 11:37 PM
Doward's Avatar
Unplug the MAP sensor, see if it makes any difference.
If so, there is your culprit
Old Apr 2, 2006 | 12:17 PM
91 v6's Avatar
Engine: 3.1l
tried that no change this morning went to start the car and it runs for a couple sec and stalls. found a vaccume line to the smog pump unhooked but that didn't change it. going to pick up an iac valve, mine is really hard to move in and out, and also exchange the ecu that i put in a couple weeks ago. welded on my lca's and trac bar last week so who knows, maybe did something to that. any other ideas, you know what to do thanks dan
Old Apr 3, 2006 | 09:28 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
its not supposed to move by hand you just ruined it you will need a new one now. Did you unplug the ECU when you were welding on the car?
Old Apr 3, 2006 | 09:45 PM
91 v6's Avatar
Engine: 3.1l
ya already put one in and swapped the computer out, it was under warrenty anyway. when i unplugged the map it didnt change anything but today unplugged the vaccume to it and started it and it ran. then as soon as i took off up the street it died again so i guess thats probally it
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
