Runner length??
Old Apr 15, 2006 | 02:14 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Runner length??
Ive been hearing mixed answers with this question and was wondering if someone could help.. Do shorter length runners give you top end power, or longer ones? Thanks
Old Apr 15, 2006 | 03:59 AM
molopaa's Avatar
Car: 83' Pontiac Firebird
Engine: 2.8 V6
If I remember correctly short runners give you top end power, but low torque suffers. Long runners give great torque down low, but kill top end power.
Correct me if I'm wrong. (As if I had to ask)
Old Apr 15, 2006 | 04:16 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
^ yes you are correct.
Most runners under 4-5" are killer top end, decent medium nothing down low.
You go to 7-8" and up and the extreme swings the other way.
An example, look at the stock L98 runner length of around 7-8 range, then look at the same engine with the holley stealh ram 4-5" intake on it. The stock intake kills the HSR on the bottom end (up to -22hp), but once you get above 3500 the HSR absolutely demolishes (+26-up) the stocker.
Old Apr 15, 2006 | 10:00 AM
So would 6 inch runners be good on a 660?? What are the stock lengths?
Old Apr 15, 2006 | 02:05 PM
V6sucker's Avatar
Engine: blown up
well 2 on the top. 4-5 intermediate. 1-2 head. so around 8-10"
To answer the question is impossible. What is good for one person is bad for another.
Yes this is another one of those "personal preference" things. It depends on where you want the power, and whay type.
Old Apr 15, 2006 | 02:19 PM
daves12secV6's Avatar
runner volume also has alot to do with it to, i really cant be much help caus eim one of those big carbed motor guys,but im doing the whole learniong this myself with this turbo 60*v6
Old Apr 16, 2006 | 11:40 AM
V6sucker's Avatar
Engine: blown up
yes volume does play a part. But with everything being equal or close to head port size that rule applies.
In turbo apps even more.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
Scorched1984
Sep 15, 2015 03:42 PM
