'86 Firebird will not run
Old May 4, 2006 | 07:06 PM
misterp53's Avatar
Car: '86 Firebird
Engine: 2.8L MPFI
Transmission: Automatic
Some background: 86 2.8 MPFI, compression 120 to 150 psi, spark at all plugs, timing verified at 10 BTDC, fuel pressure 35 - 40 psi, fuel flow 1/2 pint+ in 15 sec, voltage verified on hot side of injector harness, cranks well and will start once or twice but will not run with key released, code 34 showing on ALDL query.
Engine will start and run smoothly if fuel is atomizeded into the throtle body while cranking. Is there a reliable way to check the injectors without noid lights or a scan tool?
Old May 4, 2006 | 07:55 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
what is the fuel pressure dropping to when you crank?
Old May 4, 2006 | 08:51 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
fp should be about 45 at idle, code 34 is MAF sensor, unplug it and try running the car
Old May 4, 2006 | 09:27 PM
misterp53's Avatar
Car: '86 Firebird
Engine: 2.8L MPFI
Key on pressure 36 psi, rises to 40 psi while cranking.
Old May 5, 2006 | 12:27 AM
Engine: 5.7 / 7.4
ok, then your injectors....... aren't
gives me chance to sneek a peek at the 85 service manual to see the circuit diagram (shouldn't be that different)
Old May 16, 2006 | 11:02 AM
Gymbeau's Avatar
You said "...cranks well and will start once or twice but will not run with key released." Could this be an ignition switch problem?
Old May 16, 2006 | 10:00 PM
misterp53's Avatar
Car: '86 Firebird
Engine: 2.8L MPFI
Engine will run with key released if fuel is sprayed into the throtle opening.
Maf disconnected, no change.
Old May 17, 2006 | 05:22 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
You aren't getting fuel. Do a quick ohm test on all 6 injectors.
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
justin57
Aug 20, 2015 07:05 PM
armybyrd
Aug 10, 2015 09:23 PM
