3.4...opposed to 3.1
Car: 1992 Firebird
Engine: 3.1 V6
Engine parts are interchangable right? For example fttp.net has a comp cam kit for the 3.4 that I'm interested in. It includes lifters, timing chain set, etc. Will these work with my 3.1? Thanks...
Car: 1998 Camaro Z28
Engine: 6.0L
anything under the valve covers is interchangable. the intakes are different and all the stuff that bolts on to the outside of the engine are different. but internals are all interchangable.
Transmission: 5-speed/T-5
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
If your running the 3.4 ecm system, the cam has to have a cam sensor trigger.
If your running the 2.8/3.1 ecm system, its all good.
Elephantismo
Feb 13, 2019 12:51 AM
