Anyone tried this cam?
Old May 23, 2006 | 09:43 PM
jdk1987's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Found this Melling M-Select Class 1 Camshaft on summit. Advertised Duration 278/288, Lift .420/.443 ....
Brand: Melling Engine Parts
Product Line: Melling M-Select Class 1 Camshafts
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,000-4,200 RPM
Intake Duration at 050 inch Lift: 204
Exhaust Duration at 050 inch Lift: 214
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Intake Duration: 278
Advertised Exhaust Duration: 288
Advertised Duration: 278 int./288 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.420 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.443 in.
Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.443 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Performance-minded camshafts for the street.
These Melling M-Select Class 1 camshafts are perfect for any ride. They have good idle quality, low rpm torque, and midrange performance. These cams will work with stock or slightly modified engines with manual or automatic transmissions.
Soooo...anyone have it? Anyone two cents? Thanks...
Old May 24, 2006 | 05:43 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
sounds like the mtc-5. Which 3 people on this board have it.
Old May 25, 2006 | 11:13 AM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
could you add a link to this product, ive been looking for a good cam....thanks
Old May 25, 2006 | 12:46 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have the same cam in both the 2.8 and 3.4 in my GMC.
Old May 25, 2006 | 03:21 PM
Car: 92 Camaro RS
Engine: 5.0L
fast355, and? how do you like the cam?
Old May 26, 2006 | 01:04 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Doesn't look like an MTC-5 to me.... (those duration nunmbers look a little high). ANyhow, if it IS an MTC-5 (because my memory sucks ballz), I liked it in my 3.4L car. Knocked a half a second off my 1/8 mile run, adn I picked up 4 mph. (That cam can take a LOT of timing advance).
Old May 26, 2006 | 07:19 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Fbod, that is the MTC-5, ive got it in my 3.4 too, good cam.
Old May 26, 2006 | 09:11 AM
Dale's Avatar
Engine: 350 S-TPI
Mines going back in this weekend
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
