Kill switch
Old Jun 1, 2006 | 05:39 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Kill switch
I want to stick a kill switch on my camaro, I was thinking under the ash tray. I was thinking of splicing into the neutral safety lockout. Is that on the shifter or in the trans, and what color? Thanks
Old Jun 1, 2006 | 08:47 PM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
I have that setup, on my car its a purple wire in the wire harness on the shifter. Spliced the wires and ran the switch through a relay that closes when the defroster is on!
Old Jun 1, 2006 | 09:22 PM
Toehead's Avatar
that's so sneaky, I love it lol. You have inspired me to try to be a bit more creative. Now to brainstorm
Edit-
How about this- If you aren't wearing your seatbelt, the car wont start. I dont't think a potential thief, crouched under the dash to access the ignition wires, will have his seatbelt on When I took my car apart, I noticed that the drivers seatbelt had an electical connection on it. What was the purpose of that connection, and can I uses it to implement this idea?
Edit- I was impatient, so I got out my multimeter and ripped it apart. The electrical connection is a seatlbelt buzzer of sorts... grounded when the sealtbelt is not worn, and disconnected when worn. I can get the switch to work with a simple relay. Do you think the switch can handle the relay current? Also, are there any power sources active only when cranking which I can use to power my relay?
Old Jun 2, 2006 | 08:41 PM
Car: '88 Camaro
Engine: v6-173-2.8L
I used the defroster because you can only turn it on when the ignition is turned, and I was afraid of the relay current taking away juice from the defroster so I installed a momentary switch in series with the relay coil. So when I get in the car I turn the ignition turn on the defroster then hold in the hidden momentary switch and turn the key!! The seatbelt idea is good, I wish I would have put more thought into it.
Old Jun 2, 2006 | 10:50 PM
daves12secV6's Avatar
one of my friends had a kill switch hooked to his high beams to start the car u would have to turn the high beams on
Old Jun 3, 2006 | 08:50 PM
Toehead's Avatar
got it working
Old Jun 3, 2006 | 09:43 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have problems with people steeling crap outta the car, not trying to take it. Some creative thoughts given in here.
Old Jun 4, 2006 | 12:10 AM
Toehead's Avatar
for all future reference, the pink wire with a black stripe is an ignition switched power source that is not interrupted when starting. It supplies an ignition switched signal to the cruise control, and defroster.
Old Jun 4, 2006 | 10:21 PM
bassrider20hz's Avatar
how about if you make a switch using the ciggarette lighter since its hidden inside of the ashtray (at least for me) and using a relay to put it on the coil so there is no spark to the sparkplugs. or is cutting the power to the coil bad??
Old Jun 4, 2006 | 11:09 PM
Car: '88 Camaro
Engine: v6-173-2.8L
I thought about killing the power to the coil, but my mechanic told me not to. I don't see a problem if your using a good relay.
Do all camaros use the same seatbelt setup? With the wiring and all, I want to install another kill switch like Toehead. This way my dad will be forced to buckle up!
Veaceonee
Sep 29, 2016 08:15 PM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
luvofjah
Sep 3, 2015 07:08 PM
