V6 roller cam
Old Jun 8, 2006 | 09:53 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
V6 roller cam
I found a hyd roller cam for the V6, and I'm curious whether anyone has tried one of these.
They don't list much in the way of specs.
I have an alum head 3.1l from a '90 Corsica (FWD) that I might build up.
24505674
Old Jun 9, 2006 | 03:33 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
roller cams will not work on the RWD 60*s without extensive machining. the oil galleys are too small to feed enough oil up to the cam, so ive read. i think doward posted something on this a while back.
Old Jun 10, 2006 | 01:58 PM
Car: '85 IROC
Engine: LB9
I tried searching for a thread by doward with info on that... no luck.
Also the # shown on the first post is supposed to be a link, click for more info.
Old Jun 10, 2006 | 04:57 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
grab a welder, some stock, and make a mount for the (gen 2 or 3) fwd block to fit in, or buy the aluminum 2.8 bow tie block. either will give you improved oiling for roller cam
Old Jun 10, 2006 | 08:35 PM
Car: '85 IROC
Engine: LB9
Do you have that cam?
I'm a lot more familiar with th V8s than V6s.
I already have a FWD genII (I think) It's a '90 3.1l from a Corsica. alum heads, splayed valves...
I can't help but wonder what it is about a roller cam that needs better lubrication than a flat tappet cam though??
Is it the journals?
In the V8 they're interchangable with the right parts, and it's always been my understanding that the flat tappet demanded more oil than a roller.
Old Jun 15, 2006 | 09:11 PM
Car: '85 IROC
Engine: LB9
TTT
I have been searching and making calls to try to find out anything on the above mentioned cam, and all I've been able to get is that it's the factory stock hyd roller for the 3.4l v6, which I assume is a 60deg.
You can click on the part# in the first post for a link. But there is very limited info there.
I'm hoping that someone here can tell me something.
If the numbers are in the ballpark for a good economical street engine, I'd get one and adapt it to work in my block if possible.
My block is a 2nd gen 60deg 3.1.
Any info would be greatly appreciated.
TIA
Old Jun 17, 2006 | 08:53 AM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
all RWD 60* v6's are hyd. flat tappet, there was no factory hyd. roller. the fwd 3400, probably, but thats a differnet monster, a good hyd. flat tappet will do good, dont get a cam that you dont know any specs on.
Old Jun 17, 2006 | 09:29 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
What would a good cam be for a supercharger?? I know for turbos you need low overlap.. Is there any special grind needed for a supercharger as well??
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
