Anyone have 'double' roller rockers in their 2.8/3.4
Old Jun 25, 2006 | 10:48 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
If so, do they fit under our valve covers? I'd have to change the studs too I guess. I found some on Jegs for not much more than regular roller tip rockers.
I need to hurry up and order a set for my 3.4 now that I'm in the process of assembly.
Edit: Did some searching, I should mention I'm most likely going with the 1.52 rockers. The Compcams 10mm 12 set rockers are $112, but for $148 there's a set of "proform" 1.5 double rollers. That's why I was wondering about it for only $36 and the work of installing different studs.
Old Jun 26, 2006 | 07:07 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I tryed some proforms before, not sure on the part number. They didnt fit.
IIRC, the roller tipped comp cams will fit. 1.52 should be fine under stock covers, I belive its the 1.6 that you have problems.
Old Jun 26, 2006 | 07:18 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
yes the comp cams 1.52 roller tip rockers will fit, i have them. you need fiero valve covers to make the 1.6 fit, otherwise they bang the top of the valve cover.
Old Jun 26, 2006 | 12:18 PM
Engine: 3.4
Yeah, from the forum searching, I was already sure about the 1.52 roller tipped, and I knew the 1.6 needed different valve covers, it was the 1.52 double rollers I wasn't sure about. I think I'll just get the compcams 1.52's.
Old Jun 26, 2006 | 10:56 PM
DRR's Avatar
DRR
Car: Nothing stock- I screw with everyth
Engine: Hook&Ladder #8
Transmission: Morris Code
Axle/Gears: AxleROse CD Collection & Scuba Gear
Just in case you don't know, you can't run 1.6 rockers on stock cam and valvesprings. 1.52's is the most you want to go unless you have the heads fitted with better springs.
Old Jun 27, 2006 | 12:11 AM
Engine: 3.4
The kit I ordered came with double springs, but I went ahead and ordered the 1.52's this morning.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
