HELP pleasee!!!!
Old Jun 22, 2006 | 01:19 AM
billyshizzleyo's Avatar
HELP pleasee!!!!
hi im new here i hope this is the right place for this...
well anyway about 2 days ago i got a 91 firebird and it has noo torque at all!! it takes forever to get up to speed.
when its cold, after i first start it it has power untill it warms up. i put new plugs, wires, dist cap, air filter, changed the oil and filter, checked the atf and thats good...
i just dont have a clue what it could be...does anyone have any ideas on what it could be??
please help me..im getting passed by soccer moms on the highway!!!!
Old Jun 22, 2006 | 02:47 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
well from just what im hearing i would think perhaps your trans is slipin or sumthing espeacialy if its losing power when it gets warmed up.,,.but then again there could be alot of facters,..,if the trans fluied is nice and red in color and does NOT smell burnt then it should be ok ,.and something as simple as a kick down cable from it.,.,seems your new do a search first its a great feature!
Old Jun 22, 2006 | 09:44 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Also, get a fuel pressure gauge and watch what happens to the fuel pressure when the car warms up.
Old Jun 22, 2006 | 10:29 AM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Since you just got it 2 days ago, the color or smell of the ATF could be irrelevent. The previous owner may have put new fluid in 3 days ago! Does it feel like its bogged down at all? Is it revving high, but you're not going anywhere? Does it make a difference if you manually shift?
Old Jun 22, 2006 | 12:23 PM
it does rev really high and i dont go anywhere
Old Jun 22, 2006 | 12:36 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
if its revving really high and you arent going anywhere id be forced to say that somethings slipping...
5 speed or 700 r4 automatic?
nevermind, i re-read your post, its an auto, my 85 trans am did the same thing and shortly down the road, i was out a transmission...how much did u pay for the car and how many miles?
Last edited by 1988CamaroSC; Jun 22, 2006 at 12:38 PM. Reason: Automerged Doublepost
Old Jun 22, 2006 | 03:33 PM
Is it like that in all gears?
You should be able to check out First and Second at least, maybe Third?
Old Jun 22, 2006 | 11:33 PM
well i manually shifted it and its a lil better...but not much
and the car has 96k miles on it , and its kinda funny how i got it...i had a 92 ford escort and it needed a clutch the headgasket was going, it was messed up in alot of areas but i put a system in it and this dumb ***** kid traded me the firebird straight up for it and my escort had double the miles on it....any way i was thinkin it might be the torque converter?? ...now i know this aint the right area to be askin.
Old Jun 27, 2006 | 10:51 PM
Zeikjds's Avatar
Car: 1986 Trans Am/1993 Trans Am
Engine: 305 .030 over built/ LT1 Bolt Ons
Transmission: t5/700r4
Axle/Gears: 3.43 Posi/3.23 Posi
It has to be that the tranny is going out. Doubtable the torque convertor if it revs and you dont go. So at least you didnt get what I got...
Trade a 2000 Neon and got a 91 firebird that has burnt ATF and oil is black, plugs were loose and completely shot...got it a week ago, been doin body work but by this weekend i should have that done so i can see what it can do
I Roc Blazin
Apr 2, 2014 06:08 AM
calicompliant
Mar 8, 2012 07:43 PM
Badass19905.7
Feb 2, 2010 11:51 PM
patricksmithahh
Dec 15, 2009 07:38 AM
