Got the replacement headers
Old Jul 10, 2006 | 03:32 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Came with the bolts and gaskets this time too. Only problem now is that the crossover section is too long. It is however bent correctly, so shortening it will be pretty easy.
I could either cut it, measure the heck out of it, and re-weld it together.....Or, Cut out a section, get a slightly larger piece, slip the 2 halves into it, and bolt it together completely and re-weld.
I pretty happy anyway since these should clear the bigger oilfilter, and they came with the bolts/gasket kit, which will save a lot of money and running around.
the actual header gaskets have been replaced already with felpro's, but should I do the same with the lower pipe gasket too?
Old Jul 11, 2006 | 12:03 PM
Engine: 3.4
Actually since I need to shorten it 2 inches I'll cut out 1-1.5 inches and have one half of it widened slightly. Then I can just slip one section into the other.
Old Jul 11, 2006 | 03:46 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
WTF? So much inconsistancy from them.
Old Jul 11, 2006 | 05:56 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yeah, aren't YOU stillowed a replacement set????
Old Jul 11, 2006 | 07:24 PM
Dale's Avatar
Engine: 350 S-TPI
Technically, yes. However, being over a year old, I dunno if they still will.
Old Jul 11, 2006 | 10:03 PM
Engine: 3.4
Summit stands by what they sell I guess.
The headers I returned were the ones I ordered back in Jan 05 just before going to Iraq for a year.
It wasn't until last week that I tried installing them on the engine (3.4 on the stand) and found out one piece was goofy. I told the customer service guy what the deal was about why it took so long and he said,
"no problem, we'll send a ups truck out to pick'em up and send you a new set, and if they don't have the bolts this time, call us and we'll get those sent too."
Anyway, shortening the pipe is pretty simple, and I just want to get this swap underway, so I'll shorten it.
Old Nov 9, 2006 | 06:14 AM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
Always use new gaskets on exhaust systems and if you can stand the stink use copper coat. What brand are the third gen 60 degree V-6 headers?
Old Nov 9, 2006 | 06:43 AM
daves12secV6's Avatar
that copper **** does stink i use it on my turbo for the inlet and outlet gaskets,only really stinks for a day though till the stuff is fully cured
Old Nov 10, 2006 | 06:13 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
yeah ya gotta love that smell.......first time I used it I thought I broke my car lol
Reddeath210
Oct 6, 2015 08:20 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
Out-Cast
Aug 22, 2015 07:49 PM
mdtoren
Aug 16, 2015 05:45 PM
