1982-1984 2.8l
Old Aug 2, 2006 | 05:15 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
1982-1984 2.8l
Whats the lifetime i can expect from an 84' 2.8l with 88,000miles. Ive heard people say they shoot rods alot becuz something due to a a weak crankshaft. Also are the remanufactered 2.8l engines any good becuz if mine does shoot a rod that will probaly be my investment. So if you guys may know something about these motors please post. BTW these are the carbed 2.8l's.
Old Aug 2, 2006 | 05:21 PM
j dezzy's Avatar
Car: 87 TA
I'm not sure about the old carb'd ones. but when I had a 2.8 MPFI in my 87 I ran it into the ground. that V6 would go anywhere and never quit or foul up at all. didn't get the best gas milage but even after taking some serious abuse I pulled it in working condition and sold it for $250
Old Aug 2, 2006 | 06:07 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
if it does blow up, go with a 3.4, but the milage is pretty good, i'd worry about other things before worrying about the motor unless you drive it like you stole it.
Old Aug 2, 2006 | 06:30 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
GM 60-Degree V6 engine - Wikipedia, the free encyclopedia
GEN I starting with LE2
im trying to find specific info about the bottom end design of these engines though
Old Aug 2, 2006 | 06:50 PM
Car: 84' Trans Am
I believe mine is a LC1
Old Aug 2, 2006 | 08:31 PM
daves12secV6's Avatar
im not exactly sure but i belive the bottom end is the same as the mpfi cars.and if it is its good to 7,000 rpm and 400 hp
Old Aug 6, 2006 | 08:14 PM
Car: 84' Trans Am
Bump...
Old Aug 7, 2006 | 08:03 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
I have over 190,000 miles on the '84 and IIRC there are members on here that have well over 200k on theirs. The '84 still runs well although it leaks enough oil to start a small middle eastern oil cartel.
Old Aug 7, 2006 | 12:57 PM
MNformula350's Avatar
My old 84 2.8L V6 5 Speed went 288,000 before I blew a head gasket, and I just parted it out, cause the frame was rotted. That and I had only paid $100.00 for it a year earlier, used it for a Daily Driver, and put 60,000 or so on it. ANd they were not the most gentle miles either LOL
Old Aug 7, 2006 | 01:03 PM
Car: 84' Trans Am
Well they sound like good motors, definetly not the most powerful either.lol Thanks for the input guys.
Old Aug 15, 2006 | 03:32 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
my 83, before i wrecked it had 93k miles on it, i beat the car to hell (engine wise) and it was still running strong, even now since its recked the engine is still running (no damage to the engine, just body) they are very good engines, just make sure you find all your vacume leaks.
Old Aug 15, 2006 | 03:41 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
my 91 3.1Li has 191k now and still my daily driver.
try a little thicker oil so u have less chance of having a knock.
engine should run for over 200k for sure,
things to worry about is other components like water pump, fuel pump,
and all these small things which shouldnt be too hard to fix.
just maintain it well and car will run for ya
Old Aug 16, 2006 | 08:56 PM
~87Bird~2.8~'s Avatar
Car: 87 Firebird
Engine: Was 2.8, Now 350
Transmission: V6 T-5
Axle/Gears: 3.45 Open
my car had the fuel injected 2.8 and it had about 260,000 KM (mostly highway) when it spun a bearing after over heating/due too/same time as...worked great up till then tho...
bplessy
Sep 30, 2015 12:14 PM
88rscamar0
Sep 23, 2015 09:08 PM
64goatman
Sep 9, 2015 01:09 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
