Maybe time for another dizzy...(pic)
Old Aug 27, 2006 | 05:18 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Ok...after I did the tune-up today, I looked at the dist. cap. It looks like the rotor button has just dug into the cap. I know the pic is'nt all that hot, but you can kinda see what I mean. Is the shaft done got worn out making it do this? I know last week the car did'nt run that good, so after I got home I noticed the dist. cap was loose. I tightened it up and it stayed tight til the tune-up. Could it being loose like that for 1 day have made the rotor do that?
Ken
Old Aug 27, 2006 | 05:52 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
you can check to see if the shaft is worn by simply trying to wiggle it with the cap off. also, make sure that the rotor is pushed all the way down on the top of the shaft.
Old Aug 28, 2006 | 05:40 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i would think that even running for a lil while like that would cause that problem. that things spinning pretty quick inside there.
1984HO
Mar 19, 2021 11:59 AM
BADNBLK
Nov 16, 2016 09:12 AM
project89
Sep 24, 2015 06:38 AM
Linson
Aug 21, 2015 02:12 PM
cstrobel65
Aug 15, 2015 10:19 AM
