1984 Fuel Pump?
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
1984 Fuel Pump?
I think my car issues are all steaming from another bad fuel pump, and I am tired of the mechanical pump the 2.8, carbed engine has. Does anyone know of a good, low PSI electronic pump to use in this instance? I would be bolting it on the underbody or under the hood. I beleive the 2.8 carbed engines on;y need ike 4-6 psi and I can not find any small end fuel pumps.
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Just look for any pump designed for carb'd vehicles, it doesn't really matter for your kind of application, any pump that puts out low pressure will do well for you.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Holley "Red" pump JEGS High Performance - Holley Electric Fuel Pumps
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
As already mentioned, any carburetor designed electric fuel pump will do the trick. Just be sure to run an adjustable fuel pressure regulator (the Mallory 4309 is a good piece, it can be lowered down to 3-psi), as well as utilizing your stock fuel return line...
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
return line? on an E2SE 2bbl?? Mine just has the hard line off the fuel pump to the filter housing off the float bowl...so did my '83 when I had that one...
I had an electric pump on the '83, ordered it at Napa for $25 or so. From what I hear, you're supposed to wire it up to the oil pressure sender so it won't run after the engine stalls (handy in the event of an accident). Mine was wired up straight off the ignition by the previous owner...didn't learn about a safer way to do it until the '83 had been long since dead. I'll be going to an electric on my '84 with the engine swap I'm doing. The adjustable regulator is definitely a good idea.
Engine: 5.7 / 7.4
I have the 4309 on my ride now. E-bay WILL be your freind in gettign a good price. Mine came w/a gauge & all parts for about $35. new price is around $70 iirc
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
