maf to sd ??? need help
Old Sep 5, 2006 | 12:24 AM
daves12secV6's Avatar
alright im gonna be droping a stock 3.1 back in the car fo rthe time being since i need to be able to drive the car until my 3.4 is done,since i am gonna drop my original turbo system on the 3.1,i figured id swap over to sd..
heres the deal i bought a very low milage 3.1 out of a 92.im getting engine/trans along with the harness and ecm. well the harness is still pluge dinto the engine sensors etc,it was just disconected from the ecm and various other car harnesses.hvac controls and such.
now is it possible for me to just drop this engine/harness in , plug in the sd ecm/harness and be done,or is there some sort of mods that have to be done to the harness for it to fit my car
Old Sep 5, 2006 | 02:56 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Should be a direct hook up, however, if you still have access to the donor car (especially if it's a junker), I would consider cutting the connector's (with a few inches of wire) leading from behind the dash (ALDL etc), to the ECM, just in case....
Old Sep 5, 2006 | 05:53 PM
the biggest concern i have would be the sd cars used an elctronic speedo,im getting the dash harness along with the engine harness as well
Old Sep 5, 2006 | 09:37 PM
You aquired the tranny as well, so it should be a pretty straight-forward swap then...
Old Sep 6, 2006 | 06:37 PM
yes but isnt the plug for the electric speedo on the interior harness and not the engine harness?
Old Sep 14, 2006 | 10:33 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I thought all post '85 f-bodies had electric speedos?
Old Sep 17, 2006 | 12:02 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Geez, Daves12sec, you're not scoring all my stuff outta my favorite junkyard, are ya?
Electric speedos only came on +85 cars with "Full Gauge Packages"... I have one out of an '87 car, along with the VSS and buffer box (H&H jyard, $free). If the '86 v6 just had gas & speedo, it got a mechanical speedo with VSS in the rear of the speedo.
I remember KED85 (Karl, RIP) said that the only diff between a full gauge package (electronic speedo) v6/v8 was a "scratch" in the pc board for the tach.
AsFarAsIRemember, you'll be OK with just the engine harness. I think the ECM will still need a buffer box connection from the VSS buffer- and your 2.8's mechanical buffer box will "probably" be able to be wired up. If not, hey, that's why we're on these forums
Old Sep 17, 2006 | 09:36 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
My bird came w/full gauges & mechanical spedo. iirc (yeah, haven't searched teh plethora of results that wouldbe involved), all birds(w/regular instrumentation, not digital) got full vss in 87, and the maros got it a yr later. iirc.
Old Sep 17, 2006 | 07:18 PM
Tom, what part of Central New York, <cough> I mean Jersey are you from (neighborhood is changing, for the worse)?
Can you believe that B&B is selling, Dave? That's the only freaking boneyard in our area that has loads of F-Bodies (unless both you and Tom know something I don't)...
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
