180-200Hp without turbo or NOS
Old Sep 17, 2006 | 05:56 AM
adie's Avatar
Car: Pontiac Firebird
Engine: 2.8 v6
Transmission: auto
Hi there
Is it possible to get 180-200hp without turbos or nos on a 2.8.I'm looking to get v8 performace without an engine change.As these engines are quite low compression ratio has anyone skimmed the heads to increase this,if so how much and did it work.
Old Sep 17, 2006 | 08:27 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
. thatll tell ya probably everything you wanna know
Old Sep 17, 2006 | 08:32 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Yeah, I prefer Nitrous eXpress anyway, NOS seems to be behind in advancements.
Old Sep 18, 2006 | 04:53 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
shaving the heads isn't the brightest idea, they amke up the landing between the block and intake manifold- so if you shave them, you'll have a gap and a bad vaccum leak. You can get aftermarket pistons, prolly cost about 500-800 bux or so, that'll bump the compression up for you. GM has been able to get like 300 hp out of the 2.8L in N/A trim...how they did it, I dunno.
Old Sep 18, 2006 | 05:02 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Originally Posted by FbodTrek
shaving the heads isn't the brightest idea, they make up the landing between the block and intake manifold- so if you shave them, you'll have a gap and a bad vaccum leak.
I believe the common practice is to machine the intake as well.
Old Sep 18, 2006 | 05:49 PM
daves12secV6's Avatar
u can mill the heads,but u have to have the manifold milled as well.cast pistions are cheap and imo are a better option.compression will only help so much,u need to have the heads ported.
ported heads,10.0-1 cr,decent cam/w high ratio rockers,headers and a catback should get u right were u want to be,though to get the most out of the mods u will need to get a custom chip burned for ur mods.also if u want to go faster wieght reductions help big time in heavy cars with low power engine,more then in a car that has a more powerfull engine upto a point
Old Sep 18, 2006 | 08:09 PM
FbodTrek's Avatar
Or if you want to get crazy, 13.0:1 compression, ported heads, oversized intake valves, deshrouded exhaust valve landings, lumpy cam, and bikirom utilizing 104 octane or so.
Old Sep 19, 2006 | 01:59 AM
adie's Avatar
Engine: 2.8 v6
Transmission: auto
Thanks guys
Didnt really think about new pistons, but I'm stripping out the engine soon as its got a bottom end knock,where could I get these cast pistons to raise the compression ratio and any idea how much they cost.
Old Sep 19, 2006 | 02:06 AM
gm sells them so does trw/federal mogul. im sure other places do as wlel u just need to look around
Hotrodboba400
Dec 10, 2019 07:07 PM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
