3.1 upper on 2.8?
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
3.1 upper on 2.8?
My local bone yard has several 3.1 Camaros (and a Firebird). I was thinking about getting a 3.1 upper intake plenum for my 2.8 mainly so I could delete that plastic IAC tube. Will my 2.8 IAC work with the 3.1 upper?
20 views with no responces? Someone must know the answer to this.
If what you were saying made any sense at all, you'd probably have more replies.
The plastic iac tube? Last time I checked the MPFI 2.8 uses the same style IAC and TPS as most TPI cars, while the 3.1L uses the later style compact IAC and TPS. Neither configuration uses a plastic tube for the IAC.
Theoretically, a 3.1L intake plenum would work on a 2.8L, but there would really be no advantage since the plenum really has nothing to do with the IAC. It does however have to do with the EGR system on the 3.1L. If you wanted to change IAC styles from early to late you would want to change the throttle body, not the plenum. Incidently both early and late style TPS/IAC use the same wiring, just different plugs. Clip and splice the late style plugs into your harness and you could plug and play, but honestly I still can't see any reason why you'd want to do that.
Perhaps you should try posting a picture of what you're talking about, or consult a service manual for your car and figure out the proper terminology.
Drew, perhaps you should do a little more research before flaming me. I am very familiar with the LB8 but not so much the slight, but important differences in the LH0.
On the LB8, YES, there is a PLASTIC tube from the throttle body (from the IAC housing to be exact) which runs under the upper intake manifold and into a fitting (the same fitting used by the PCV valve) at the rear top of the lower intake manifold. When the IAC valve opens, engine vacuum pulls air through this tube into the intake manifold. The 3.1s use a slightly different IAC setup which eliminates this tube. Perhaps the only difference is the throttle body. I don't know (which is why I asked). Perhaps I should have asked, "is the 3.1s IAC setup compatable with the 2.8?" or "will the 3.1 throttle body work with the 2.8 intake and retain IAC functionality?" Since I know how the 2.8s system works, but not the 3.1s I thought I might find someone on here who would know the answer.
Instead I got you.
Instead I got you.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I'm tryind to draw myself a mental picture of your throttle body and intake manifold. On mine throttle body, the IAC housing has to vacuum lines leading to the fuel pressure regulator, as well as the vapor canister. Ahead of the throttle body (on the rubber intake tract), there is a plastic line that leads to the valve cover (as you already pointed out, the same type of fitting for the PCV)...
In any event, swapping manifolds wouldn't cause a problem at all... so long as your PCV is still functional. From one of the diagrams that I'm looking at it right now ('89 2.8), there is nothing computer related over by the rear upper side of the lower intake half. So long as it gets plugged, you'll be fine, however, idle might be affected slightly, so it'll need to be reset.
Thanks Street Lethal. Attached is a pic of my intake. The large black plastic tube on the pass side of the TB coming off the IAC housing at about a 35* angle and running under the upper intake is what I am referring to (see arrow). The 3.1s don't have this. But can I just swap the TB as the IAC air bleed is obviously routed differently? Or is the 3.1s manifold a part of that system as well?
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
Ya.. the IAC pulls its air from the Block.. if you follow it back it goes to the driverside valve cover.. My PVC tube got clogged up and it would start.. took me days and a lot of hair pulling to figure it out.. And on the smog stuff.. I didnt know if U had it or not.. but the IAC does need that to run for some stupid reason.. And I dont know ur smog laws up there.. That way I said "if" ur in a smog controlled area..
Diffrent year may have a slighty diffrent set up// mine runs right to the valve cover.. Im also in Ca and have a CA smog set up..
The '88 LB8 should be the same as mine, though California car may be different(?) Its not easy to see, but the tube from your PCV valve connects to a "Y" branch at the rear of the intake manifold. One branch of the "Y" goes to the IAC tube and the other connects to a vacuum port on the intake manifold. Other branches off these tubes go to various emissions controls, but those are long gone on my engine so I have no point of reference.
...I purposely blocked off that tube once and started the engine just fine but the engine would not idle without the TB being cracked open slightly.
If that is the case, I'd remove that plastic line, plug up the vacuum fittings associated with it, raise your idle speed manually by hand, wait for the engine to reach normal operating temperature, then re-set it's idle...
If I'm misunderstanding the query, please elaborate for me once more...
The IAC doesn't pull air from the block, rather vacuum from the intake pulls air in through the IAC valve to keep enough air in the intake to keep the engine running when the throttle body is closed.
Ultimately, IAC settings are predetermined from the factory (much like carburetion). Once we start plugging vacuum lines, idle speed immediately needs to be recalibrated. Controlled idle speed is determined by the factory based on total air flow including throttle valve, PCV, IAC passages and calibrated vacuum leaks. If one of these are altered at any given time, the engine gets thrown for a loop (because of the predetermined settings), and will more than likely stall...
However, the engine can simply be retuned to compensate for the changes. I think you stalled, not because you weren't getting enough air into the engine, rather, because it through the ECM for a loop (much like when we raise, or lower a controlled idle screw with a screwdriver, the ECM get's very frustrated). Once that plastic line was removed, you would have needed to reset your idle speed immediately...
I comprehend everything you said except:
This is not true when the engine is idling. Think about it, how does the engine idle when your foot is not depressing the gas pedal (ie, throttle blade closed)? The air that the engine requires to idle enters the IAC through a passage in the TB to the right of the throttle blade (see arrow). Apparently the 3.1 IAC deposits this air on the other side of the throttle blade, it kinda does an end-around and bypasses the blade. The 2.8 IAC deposits this air into the afore mentioned tube and into the intake manifold.
You are absolutely right in saying that, as I didn't explain that part properly. I was so tuned in to the concept of the IAC only measuring air flow based on vacuum pull from the intake manifold (which is why I had your explanation confused initially, as I was confused by the concept of the engine pulling air through the IAC from a non-prevalent opening), that I didn't realize you were aware that air was still being pulled in through the front of the throttle body. When I stated throttle blades, I honestly meant the front of the throttle body. Thats why I was confused. I was saying to myself, if the IAC only has a passageway leading to the intake manifold, then the engine would immediately stall with the throttle blades being completely closed. I misunderstood your explanation...
MrPackstin
Oct 25, 2017 08:09 PM
