going to megasquirt
Old Sep 20, 2006 | 11:24 PM
daves12secV6's Avatar
going to megasquirt
well since i have once again outgrown my injectors,and lowering the fp even more to compensate,im quessing the car isnt going to idle/part throttle drive very well.so ive finally broken down and bought a fully assembled mega squirt.
atleats now ill be able to do some real tunning,instead of relying on my wideband/fmu, and adfpr to do my tuning.
the main thing that was keeping me away from going with mega squirt in the first place was having to build a whole new wiring harness,but i found a guy on ebay that makes pre assembled harness,alls i have to do is cut th ewires to lenght and solde ron all the sensor/conector pigtails.
hopefully its a good as everyone says it is,but i quess ill soon find out
Old Sep 21, 2006 | 02:04 AM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
i know tons of people and tuners in houston that use it......so i guess it would be good, we always used uberdata(sp?), because my friend has a chip burner. g/l
Old Sep 21, 2006 | 06:04 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
why solder. just replace the connectors inserts. car quest/parts place has an *** load of them. I did that to fix my window connector when the wire shifted and ripped out
Old Sep 28, 2006 | 02:00 AM
wanted to know how its going????
Old Sep 28, 2006 | 02:10 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
What version Megasquirt did you get?
Old Oct 3, 2006 | 11:09 PM
hows it going with megasquirt?
Old Oct 3, 2006 | 11:13 PM
im not gonna be doing the install till over the winter when i take the car off the road.which ill do once we get our first snowfall here
Old Oct 3, 2006 | 11:49 PM
oh, ok i can wait then.
Thirim
Aug 13, 2015 03:09 PM
mhaskell
Apr 26, 2008 01:01 AM
daves12secV6
Nov 20, 2006 09:05 PM
mhaskell
Alternative Port EFI Intakes
Mar 20, 2006 11:30 AM
86bird_28v6_5spd_ramair
Aftermarket Product Review
Oct 13, 2001 09:57 PM
