Full FWD swap
Transmission: 5-speed/T-5
Let me give you the correct info...
You can, but it's not a bolt in.
If you were to use FWD parts, at least use a 1996+ 3400 or 2000+ 3100, they make so much more power and are so much more efficiant, than the genII parts.
Car: 91 RS
Engine: 5.0 tbi
well dam, a guy brought it in and needed water pump, ps pump, tensioner. did all of it for like 900 and them to intake started leaking so he gave the title and I got a couple more months till my 8s done then the lil longer till my trans is done.
does anybody know much about the carbed 2.8s?
or will that top end setup work on a carbed 84 block
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
this should help you w/most/all your questions:
https://www.thirdgen.org/forums/sear...earchid=280033
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
killerbv6.com makes conversions possible......i think check out the conversion page
Ghettobird52
Jul 5, 2024 11:18 PM
ambainb
Apr 25, 2016 09:21 PM
GVMV
Aug 16, 2015 08:01 PM
