Rear from a 87 t/a
Old Sep 27, 2006 | 07:34 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
Rear from a 87 t/a
ok i thonk i have another car,.wich is gonna be good for me to use its rear end., i just donr know nothing about t/a's this one is not a gta., just an 87 trans am., guy said it does not have origanal engine., but has a 350 instead and a manual trans,car is in good shape.,,.will the rear end work with my 91 camaro,. what stock gear ratio did the 87 t/a have? also any info on this year would be nice
Old Sep 27, 2006 | 08:16 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
An '87 TA could have had any number of ratios and over the years that rear could have been changed out. V8 cars typically came with tall ratios, like 2.73's and 3.08's unless the car was ordered with a posi or lower ratio. Just because it's a T/A does not mean much, my friends '87 T/A came with an LG4 (the 155hp 305) and a 2.73 open rear. That is assuming it is a GM ten bolt, if it was ordered with a performance axle it may be the nine bolt, go to the transmission and drivetrain board and do a search there to find the differences.
My advice is to pull the cover off, and count the teeth on the ring and pinion gears, then divide the number of teeth on the pinion into the number on the ring gear, this will tell you the ratio.
Old Sep 27, 2006 | 08:50 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
look at the tech info on the car,it'll list the engine/tranny/axle optins avaiilable for that yr
Frozer!!!
Jan 19, 2024 04:55 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
