question on 3.4 to 2.8
Old Oct 4, 2006 | 02:35 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Engine: 383 stroker AFR heads 600hp
Transmission: 700r4 stage 3
Axle/Gears: 373 9"
i got 2.8 and i found a torkerII intake will it fit 2.8 ? but do i have to carb it or can i put the plenum on it??
Old Oct 4, 2006 | 10:23 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
im curious as to what this post has to do about the 3.4. and just look at the intake, youll know if itll fit a carb or MPFI or not. give a link to where you found this intake, i can tell you more then. but as far as i know the torquer II intake is for carbed, IIRC.
Old Oct 5, 2006 | 02:35 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
well i was asking about the 3.4 supercharger i have a pic with a 2.8 with a 3.4 superchsarger on it ?? never seen one done before also i have found on the net just searching they do make a throttle body spacer for the 2.8 never knew that either man i need to look more often ha..
Old Oct 18, 2006 | 12:11 AM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
a 2.8 with a 3.4 supercharger? post the pic i wanna see this
Old Oct 18, 2006 | 01:29 AM
daves12secV6's Avatar
more then likely the supercharger in question is a fageol supercharger/blower,as far as i know they will bolt onto a 2.8/3.1/3.4
Old Oct 19, 2006 | 03:35 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
ya but where are they i haven't seen one anywhere.
Old Oct 24, 2006 | 08:51 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
2.8 SC
there is a pic of 2.8 chrome SC that you where all asking about if you wanna see it then email me a private message if u wanna c it..
i cant upload a bitmap image.
Can a 3.4 TB go on a 2.8 or a 3.4 to big of a Throttle Bodie ??
Cleotiz
Jan 6, 2018 08:56 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
E Rod
Aug 28, 2015 05:17 AM
redmaroz
Aug 16, 2015 11:40 PM
92projectcamaro
Aug 6, 2015 01:20 PM
