what do i use for datalogging a 3.1L LH0?
Old Nov 3, 2006 | 04:43 PM
Firebat's Avatar
Simply what program do I use for datalogging/monitoring a LH0 engine? Tried searching the boards, not much luck.
Can I use TTS Datamaster because I think I read the ecm is basically a TPI ecm. I like using datamaster for my LT1 and it is great, so just wondering.
Old Nov 3, 2006 | 05:59 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Mr.Bat (or is it Sir Fire?) I have been told that tunerpro RT will read it- but my laptop fried before I got the chance to get an ALDL cable to find out. However, I borrowed a friend's Auto-X ray and it worked fine, though unlike using a computer you can't really save the data to a disc or anything.
Old Nov 4, 2006 | 02:06 PM
sixgun's Avatar
Car: '86 TPI T/A, 90 Firebird 3.1L
Engine: 3.1, 5.0 TPI
Engine Monitor tool
Ah... I use Diacom with great success.
It's an older product designed for 1981-1992 GM ECMs.
It uses it own cable though. I think it's from Rhinda tech.
I put it on an old laptop, plugged in cable, typed in VIN and
walla!
Sixgun
Old Nov 5, 2006 | 03:43 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i use tunerpro r/t and i just picked up moates ostrich unit (an emulator) which also works with tunerpro....i am very pleased with the combo!
Old Nov 8, 2006 | 11:56 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
tunerpro r/t, moates cable, compaq laptop.
Speaking of which, I need to scan it now that I have time to work on it again.
Old Nov 13, 2006 | 01:39 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
AM91Camaro,
What do you use for an .ads file. I can't get one to work. What bin are you using?
Old Nov 13, 2006 | 03:44 PM
Car: 91 Camaro
PM me with your email address and I'll email you the files I use.
In answer to your question (publicly), I use:
730_v6_90-92.ads
$88 -2.xdf (might be something I re-named it to, can't remember for sure)
and I started off with the azty.bin
HoosierinWA
Oct 7, 2015 10:15 AM
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
J.C. Denton
Aug 31, 2015 03:11 AM
bamaboy0323
Aug 15, 2015 07:20 AM
