oil pressure
Old Nov 8, 2006 | 03:24 PM
TYC-FlipSiCan's Avatar
oil pressure
is it normal for my oil pressure to idle a little over 40 on the oil pressure gauge and when running it its at70 or so or is something wrong because i remeber my car was always at 80 when i got my car??? just a little question thanks!
Old Nov 8, 2006 | 04:23 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
its not low or anything, and your gauge could be sticking a lil, most of them do that, but i wouldnt be concerned w/ it. if you wanna check it, just get an oil pressure gauge to screw in and see what the actual pressure is.
Old Nov 19, 2006 | 04:19 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Engine: 383 stroker AFR heads 600hp
Transmission: 700r4 stage 3
Axle/Gears: 373 9"
well my 89 is reading a low oil pressure what would that mean??
Old Nov 20, 2006 | 05:19 AM
drdave88's Avatar
Engine: 6.0L
whats it reading, is that at idle or cruising? you wanna get a gauge and make sure thats really what its reading. your dash gauge could be reading incorrectly, so verify thats really what it is first.
Old Nov 20, 2006 | 07:06 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
due to internal wear on compression rings
and all the main/rod bearings wear, its normal for oil pressure to drop overtime.
oil pressure constanly at 80 is only when the car is really new,
as engine gets some miles, its normal for pressure to go lower.
I dont know how many miles u got,
but my engine has 191k miles on it,
and with thick oil that I use, I get 50 when running
and 40 in idle.
as ur engine warms up pressure will drop slightly due to oil becoming thinner
and thats normal.
from 50 running and 40idle, when my engine is warmed up
it will go little above 40 running, and as low as 20 in hot idle.
so with the oilpressure you can kind of guess the condition
of internal parts. urs is nothing to worry about,
with my number Ive been driving my car everyday 30miles
and no problem its been 1year now. (although I do have unrelated other problems lol)
hope that helps
Old Nov 20, 2006 | 08:28 PM
drdave88's Avatar
Engine: 6.0L
sogabe, those numbers seem a lil on the low side, lol. you may wanna check into a rebuild soon, lol. jk, if it doesnt cause you any problems, let it roll.
Old Nov 20, 2006 | 09:34 PM
sogabe's Avatar
Engine: 3.1L
it is hella low lol
and these numbers are with 20-50 oil hehe
Old Nov 20, 2006 | 09:47 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
you could always get an new oil pressure sending unit. Try that and see if maybe thats the problem. its a fairly cheap and easy job.
Old Nov 22, 2006 | 07:19 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
RE:
well
well i got a new oil pressure sending unit last year and my block is new i got only 6k on my 2.8 i bought a new 2.8 no miles last novemeber 05 and it reads like 10 i think but i asked some one and they said they always move i thought that there supposed to be even like 40 or so but i never really paid attention but yeah it reads high when cold then when hot it goes down to like maybe 15 ???? WTF i dont really care i got a 3yr warranty till 08 so it f***s up hey another new 0miles but i just figured i ask
Old Jan 7, 2007 | 10:45 PM
Pyrice4's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1L V6
Transmission: M5
What does it mean when you give it gas and the oil pressure gets pinned all the way high??
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
