is there any ways to identify injectors?
Old Nov 9, 2006 | 12:02 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
man after reassembling my 3.1 engine back,
I have a bad misfire..
i can hear loud pop from my passenger side bank of engine around
cyl 3 and 5.
i took the plug wire out, the plug wire was burnt and the plug was cracked in no4 cylinder. so I thought woohoo easy fix!
but then with the new one in I still have the same problem.
im thinking its possible i hooked the wrong injector wires back in,
although i labeled them..
is there a color code to like which cylinder it goes to? or is there a way to identify which goes to which?
thanks in advance..ive been stuck in my garage for 4days for this..
Old Nov 9, 2006 | 05:29 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
no theyre the same for all of them. the wires should be kinda bent in the routing for them, and if you labeled them before you took them off, you should be ok.
Steve78LT
Feb 24, 2016 12:15 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Linson
Aug 21, 2015 02:12 PM
tmellott89
Aug 16, 2015 02:58 PM
