1990 Bird 3.1L V6 Fuel Injection. HELP!!
Old Dec 10, 2006 | 06:27 PM
riven_1978's Avatar
Car: 1990 Pontiac Firebird Base Model
Engine: 3.1L V6
Transmission: Automatic
I have a 1990 Pontiac Firebird which i just had to replace the oil pump. ok so i pulled the engine/tranny as one replaced the oilpump and stuffed the engine back in. Tried to start her adn the darnned thing wont start. I dont know much about cars at all and this is the first time i have dove this far into anything but wasnt going to pay 650 dollars for some one to replace a 49 dollar part. Ok, here is what i have done thus far; I checked to make sure that all my spark plugs were firingall of them were they looked fowled to me so i changed them anyway and set the gap of them to .045. Next i checked that i didnt screw up the timing which i didnt pull the distributor just the cap and i didnt take the tranny off the engine so i didnt think it would be that and found timing is good actually from the specs i have read from users on here and firebirdnation my timing is dead on. ok so spark and timing is good what else could it be. after talk to a guy i met in the next stall over i found out about the fuel injector Nodes. um ok well i plugged the node lights and didnt get any reaction found that they should have strobed so ok now i know where the problem lies the injectors arent allowing fuel from the rail to the heads, my question is how do i find out wether its the wires (where do they go) or the computer. I turn on my car all the lights come on except the check engine light which doesnt turn on at all i know it wroks cause the blasted thing was always on before i did all this cause of the O2 sensor which i replaced but i figured it should come on when ignition turns to the on postion correct? so what gives? do i have bad fuel wires or is the comp fried?
Last edited by riven_1978; Dec 10, 2006 at 06:34 PM. Reason: More Info: I sprayed a lil ether in the throttle body and she started for a few seconds
Old Dec 10, 2006 | 08:18 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There is a fuse in-line with a wire under the hood. It is on the passenger side, runs along the fender line. Closer to the front is a small rubber do-hickey. The cap pulls off and there is a 20 AMP fuse. This fuse is for the ECM.
The other item to check are the fusable links down off the starter.
RBob.
Old Dec 10, 2006 | 08:21 PM
riven_1978's Avatar
Engine: 3.1L V6
hmm
Ok hehe dumb question like i posted before not car smart at all what do the fusible links look like??
Old Dec 10, 2006 | 08:24 PM
daves12secV6's Avatar
also check the ground strap that goes to the back of the cyl head on the passenger side of the engine,if i remebr right there is also one that comes out of the main harness that goes to on of the bellhousing bolts
theres 3/4 smaller wires that come off the starter with a lil black thing a few inches from were they bolt to the starter,those are fusible links,if they go bad the wire pretty much melts in half to break the circut
Last edited by daves12secV6; Dec 10, 2006 at 08:25 PM. Reason: Automerged Doublepost
Old Dec 10, 2006 | 08:27 PM
riven_1978's Avatar
Engine: 3.1L V6
sweet
K i will check those tommorrow before i have a guy hook up to the computer he is charging me 25 dollars if he gets any kind of reading to it
Old Dec 10, 2006 | 08:32 PM
dont pay anyone to read the computer for u,u can do it urself with a paper clip,ill find u a link real fast
riven_1978's Avatar
Engine: 3.1L V6
Afterthought
Also i removed the sheathing around my wire budle to figure the wiring out in which as i was removing shattered into about a millon lil pieces i was wondering what i could use as a substitue if not buy some more anyone know the name of it or where to find some?
Old Dec 10, 2006 | 08:37 PM
https://www.thirdgen.org/service-eng...ht-error-codes
^^^^ tells u how to read the codes using a paper clip to make the chekc engine light flash the codes
u can buy more of that wire loom at just about any car audio or car parts place
btw welcome to the boards
Old Dec 10, 2006 | 08:40 PM
riven_1978's Avatar
Engine: 3.1L V6
well i guess i need to figure out why my check engine light wont come on first right?
Old Dec 10, 2006 | 08:43 PM
check what rbob said first,then try to flash codes,the computer should flash code 12 three times first,then any codes, or just 12 three more times if there are no codes.if the computer does not flash 12 3 times chances are the computer is bad.if the computer does nothing u need to make sure it is getting power,which u can check with a voltmeter or test light,if it is getting power and dosent flash anything then u also know it is bad
Old Dec 10, 2006 | 08:45 PM
riven_1978's Avatar
Engine: 3.1L V6
which pins on the wires should i hook up to to see if it is getting power?
Old Dec 10, 2006 | 08:58 PM
im unsure of wich pin to probe on the ecm to check for power,maybe somone else can chime in
Frozer!!!
Jan 19, 2024 04:55 PM
lethaldomestics
Sep 21, 2015 01:18 PM
Glowsock
Sep 6, 2015 06:40 AM
Dialed_In
Aug 20, 2015 01:45 PM
