Pacesetter headers on a 92 3.1 Question.
Old Dec 15, 2006 | 10:38 AM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Okay, I've done some searching, and heard multiple things regarding this. I'd like to get the Pacesetter headers for my 1992 3.1. My question is this : Will they be a bolt on and will it still work with the smog system and what not? Will fitting them to make them smog friendly be an issue?
Old Dec 15, 2006 | 10:47 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
They will bolt up but wont work with the 3.1 smog system. I could be wrong but I think the 2.8 has 6 smog tubes, one for each primary tube, and the 3.1 only has one, next to the egr. Mabye you could fab up a tube and make it work, but Ive never heard of anyone doing that.
Old Dec 15, 2006 | 11:05 AM
Engine: 3.1
Would not having the smog system make me fail PA emmissions tests?
Old Dec 15, 2006 | 11:21 AM
grimmcs's Avatar
Car: 91 Camaro
Im not in an emissions testing county but I think to pass you have to have it on and functioning. You may pass the sniffer test but the visual test may get you, unless the tech misses it.
Where in PA?
Old Dec 15, 2006 | 04:47 PM
Engine: 3.1
Allegheny County.
Old Dec 15, 2006 | 05:54 PM
88GTA5spd's Avatar
Car: 1999 Pontiac Firehawk
Engine: 346
Most places(in PA) the testing for smog is only visual on any vehicle older than 1995, so if you can make it look stock it should pass. Other than that they just test if your gas cap works... At least that's how it is here in Lehigh county.
Gary
Old Dec 15, 2006 | 06:01 PM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Ok I added those headers to my 92 3.1L theres no way to hook up the smog pump to the headers. Ive had to disconnect mine. With it off now my o2 sensor stays open loop which was causing my car to stall when i came to a light or was decceling down a hill.
Old Dec 19, 2006 | 04:36 PM
H8TRAFIC's Avatar
Does your car stall only when its cold or at all times- cold and hot?
Old Dec 20, 2006 | 09:52 AM
Engine: 3.1
So... these headers on a '92 3.1 aren't even remotely worth it?
Old Dec 20, 2006 | 11:18 AM
grimmcs's Avatar
Car: 91 Camaro
I wouldnt say that...Ive heard of many who put them on and had no problems.
Old Dec 21, 2006 | 09:38 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well its just your luck to get stuck with the 3.1 that didn't last very long so they didn't bother making a set for it. All you gotta do is get a welder, or find a friend with a welder and fab your own smog mount.
That or change engines.
Its not rocket science, with a welder and tad bit of testing, anyone can fab metal easy.
Old Dec 22, 2006 | 09:25 PM
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
When its fully warm but hasnt been happing at all lately kind of weird
92projectcamaro
Jan 18, 2016 08:00 AM
redformula88
Oct 14, 2015 06:08 PM
corey8084
Sep 17, 2015 02:56 PM
Ian Irvine
Sep 4, 2015 08:08 AM
