stock 2.8?
Old Dec 21, 2006 | 06:15 PM
ripdanny6262's Avatar
stock 2.8?
i got a question i have a stock berlinetta camaro with a 2.8 should it at least do a brake stand?i just did a full tune up accept fer a fuel filter which im doin tomorrow
Old Dec 21, 2006 | 07:13 PM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
Its a V6 Camaro. Don't get your hopes up. These cars weren't made for power. They were made for ppl who wanted to drive a Camaro but didn't want a gas guzzler.
Old Dec 21, 2006 | 07:58 PM
daves12secV6's Avatar
it all depends on how good ur tires are and the gear ratio in the rear
Old Dec 22, 2006 | 01:30 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Its gonna be a one-legger but you shouldnt have any trouble, my old 2.8 Camaro lit that tire right up and had no trouble leavin a 75ft strip afterwards. Put your trans in 1st gear when you do it tho otherwise it will try to shift into 2nd and die out then drop back into 1st and do it all over again. Good luck!
Old Dec 22, 2006 | 08:14 AM
k im gunna gut my converter cause they said that could be y it has no ***** 2 so well see after that
Old Dec 22, 2006 | 01:34 PM
speedped79's Avatar
Car: 1982 z28
we fixed it he had the wires mixed up on cylinders 2 and 4
Old Dec 22, 2006 | 03:29 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
with my radial 235's my 2.8 did a 2 wheel brakestand, but it took some coaxing. but im sure it wont once i put on the 245, directional tires i just got.....
Old Dec 22, 2006 | 03:31 PM
i got it 2 do a nice brakestand , wires 2 and 4 were mixed up now it runs nice
Old Dec 22, 2006 | 03:33 PM
Car: 92 Camaro RS
Engine: 5.0L
1 tire fire, or both wheels?
i find it kind of funny, my 85 trans am didnt even do 2 wheels with 215's but my maro does.....
Last edited by 1988CamaroSC; Dec 22, 2006 at 03:34 PM. Reason: Automerged Doublepost
Old Dec 22, 2006 | 03:36 PM
just one
Old Dec 22, 2006 | 05:30 PM
Car: 92 Camaro RS
Engine: 5.0L
hey look at it on the bright side, when you want to show off just put that side facing the people, then when the summers over, you only need one tire instead of two. ive already burned through 300 dollars in rear tires in my maro in about 5k miles.
Old Dec 22, 2006 | 05:34 PM
turbo2825psi's Avatar
Car: 1992 RS Camaro
Engine: 5.0 tbi
Axle/Gears: stock 10 bolt 3.08's
im running 295's on mine with the 2.8 and ive got a five speed ill light the tires up untill they blow. ive won sevral burnout contests here in vegas them v8's aint got nothing on this pint sized motor
Cleotiz
Jan 6, 2018 08:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
E Rod
Aug 28, 2015 05:17 AM
86Base
Aug 8, 2015 01:34 PM
