1992 3.1 V6 camaro Valve covers
Old Jan 8, 2007 | 03:52 PM
REDRAGTOPRS's Avatar
Where can I get a NEW set from??? My old set are all rusty from soaking in parts cleaner for a week, and the old gaskets still are attached to them. I have been unable to find new ones anywhere. Help a brother out.
Old Jan 8, 2007 | 04:51 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Check out this LINK to Summit.
Old Jan 8, 2007 | 05:10 PM
The valve covers for the link you posted were for a 2.8. My motor is a 3.1. I don't believe the flange is the same size.
Old Jan 8, 2007 | 05:19 PM
grimmcs's Avatar
Car: 91 Camaro
To my knowledge they are the same. Not 100%, but someone will shoot me down if im wrong.
Old Jan 8, 2007 | 05:43 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Try out Edelbrock. I got some for my 2.8 and I would be surprised if they did't fit a 3.1 since they are the same block.
Old Jan 8, 2007 | 07:26 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Aslong as the pvc and breather holes are the same, a 2.8 set will work. For that much, a 3.4 set will as well, and fieros will as well. Some from a s10 may work as well.
Soaking your gaskets in parts cleaner will not remove them. They have to be scraped. Odds are, and used set you get will have to have the same thing done. Local parts yard had about 6 v6 engines, all with valve covers still on them.
Old Jan 8, 2007 | 08:12 PM
I've already tried scraping them, hence why they soaked for a week. Now they are too rusted to use. I have had some people tell me that the 2.8's will work and some tell me they won't. The valve covers have to go back on before the intake plenum and egr stuff can go back on, hence why I want to get brand new 3.1 valve covers, that way I am sure they will not leak. Somebody has to still produce them, and I am shocked that nobody on here can produce a link.
Old Jan 8, 2007 | 08:42 PM
Dale's Avatar
Engine: 350 S-TPI
I dont know anyone who produces STOCK valve covers NEW. A few places make chromes etc.
Depending on the options/year of the 2.8 depends on if they will work or not. It just depends on where the holes for the pvc, breather, and oil fill are.
Old Jan 12, 2007 | 11:35 PM
AlwaysDanked's Avatar
Car: 1991 Camaro RS
Engine: 3.1mpfi swapping in a 2.8mpfi
Axle/Gears: non-posi rear
2.8l valve covers WILL NOT fit a 3.1l. ive tried.
Old Jan 13, 2007 | 05:43 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
i dont understand what the problem is, why cant you scrap the old gasket off?that dont make no sence,,have you tried useing a razor blade?? seing how a blade could literaly scrap thin strips of aluminum as it is so why cant you clean up your old ones, im not trying to be mean bro! ill wait for your responce befor i do that. lol!
oh fyi im shocked you dint try a search on it befor you got shocked we have not posted you a link like a drive thru mcdonalds..lol
just seems yer being a lil lazy not wanting to put a lil work into the gaskets and all. lol
Old Jan 13, 2007 | 08:50 AM
Dale's Avatar
Engine: 350 S-TPI
Id like to know why they wont, other then the holes for the accessorys.
Old Jan 13, 2007 | 10:56 AM
daves12secV6's Avatar
i just pulled a set from a 3.1 didnt pay much attention to them but im pretty sure they were perfect,ill check them tom when i get to the shop,and take some pics
Old Jan 18, 2007 | 09:17 AM
Car: 1991 Camaro RS
im telling you! they look like they will fit! but they wont. they are slightly off!!! unless i had a cracked out 2.8l covers
Old Jan 18, 2007 | 11:53 AM
Dale's Avatar
Engine: 350 S-TPI
Explain where they are off? Because the head castings, and intake castings for the 2.8 and 3.1 are the same. The machining is almost the same as well. Enough that I put a 2.8 lower base on my 3.1, then slapped fiero valve covers on it.
Old Jan 18, 2007 | 11:13 PM
Car: 1991 Camaro RS
i dunno, but i swear to god i tried to put them on, ive even still got the valve covers, and ive been through 2 3.1's in the last 6 months. wont fit new engine either.
where they are off: the little screw like things that come out of your engine and the valve cover has holes for and you take a deep socket (i believe 10mm?) on your ratchet. those holes dont line up similarly
Old Jul 13, 2012 | 12:32 AM
Blue1990camaro's Avatar
Re: 1992 3.1 V6 camaro Valve covers
aure u puttin them on the wrong sides? are they different per side? they are the same thing as far as i know..
Old Jul 13, 2012 | 01:11 AM
project89's Avatar
hey man check the post dates before u reply to a thread this one was last posted in , in 2007
and yes all 2.8/3.1/3.4 valve covers interchange
Old Jul 13, 2012 | 01:50 PM
oh my bad i was using the search option, looking for fiero valve covers, sorry bout that
Fireslash
Apr 11, 2016 06:43 PM
92projectcamaro
Dec 8, 2015 12:25 AM
92projectcamaro
Sep 29, 2015 07:07 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
ironbmt
Sep 27, 2015 06:00 AM
