SEFI?
Old Jan 9, 2007 | 10:34 AM
ap72's Avatar
SEFI?
can I run an SEFI setup without the SEFI cam sensor? Or do I have to stick with the batch fire MPI setup?
Old Jan 10, 2007 | 12:37 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
You have to stick with the batch fire setup.
Without a cam sensor, the ECM will never know when you are on Firing TDC for #1. As far as the ECM would be concerned, it just knows that you're at TDC on some cylinder, it doesn't care which one.
Grumpy
Mar 14, 2005 10:04 PM
Grumpy
23
Feb 22, 2004 07:12 PM
Monty
Apr 24, 2003 10:53 AM
Monty
Apr 21, 2003 10:27 AM
