Vaccume leak from valve cover?
Old Feb 11, 2007 | 08:21 PM
adam86's Avatar
Car: 1989 GTA
Transmission: Stock 700r4
Axle/Gears: 3.08 POSI
im replacing my valve cover gaskets and its a pretty big job...
i have a whistling/hissing noise when i give my car some gas and i think its coming from the leaking valve covers.
can a leak in the valve cover cause a vaccume leak?
my car runs like crap and gets 10mpg.. this is the last thing i havent done besides the timing chain.
Old Feb 11, 2007 | 08:37 PM
TB2's Avatar
TB2
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
Make sure that you dont have a hose that has come unplugged while you were changing the gaskets. Thats the most common. I saw a 3.8 once that had a bad Intake gasket on the bottom side of the Intake, and was sucking air through the interior of the motor. If you took off the oil fill cap while the motor was running, it would almost stall the motor it was so bad.
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
