problem removing fuel rail
Old Feb 12, 2007 | 04:05 PM
pairtoe's Avatar
i cant get the fuel rail off. i have all the bolts off the rail its self and the the bolts off the fuel block. but fo some reason its its stuck the back end towards the fuel block will lift, the the end toward the fule pressure regulator wont budge. i dont have the injectors off but i was told it should lift up at least a 1/2 inch with them pluged in, but i wont lift at all. am i missing something here.
also all the bolts on the lower intake are off and the lower intake is free from the block, but i cant remove it till the fuel rail is off.
Old Feb 12, 2007 | 04:28 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you're gonna have to pry it off.the o-rings are most likely what's keeping it all snug & what not
Old Feb 12, 2007 | 05:07 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
PULL HARD! lol. Since the injectors are in a V shape, it is sometimes a bear to get out. You will probably need new o-rings after your done too as you'll probably rip the stock ones. Use a non-corrosive lubricant to make assembly easier.
Old Feb 12, 2007 | 05:10 PM
firstfirebird's Avatar
Did you disconnect the fuel lines?!
Old Feb 12, 2007 | 06:46 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Use a pry bar or long screw driver and slowly and carefully pry up to lift the fuel rail and injectors out. I had to do that both times I removed the fuel rail on my car. The injector o rings get stuck to the intake.
Old Feb 12, 2007 | 07:28 PM
pairtoe's Avatar
yeah all the fuel lines are off and it will go up about an 1/2 inch but then just stops, but i didnt want to pull hard and break something, but ill give it a good yank.
but does the fuel block doesnt need to be removed? it dont seem as if it is connected to anything under the fuel rail.
Old Feb 12, 2007 | 08:12 PM
It does NOT have to be removed to get the middle intake manifold (MIM) out. I leave the fuel lines attached and just lift the rail out of the way and tilt the MIM as I pull it out from under the rail. Also if you rock the rail left to right (looking from front of car) as you lift up, might make it easier.
Old Feb 13, 2007 | 06:39 AM
pairtoe's Avatar
i tried that first, but with the fuel lines is it wont budge at all. not they there are off it has a bit off movement, but not much. and i didnt want to just go pulling it out to hard. but i guess thats what i got to do now.
so if i pull it hard enough straight up the whole thing will come ou with the injectors attached right?
Old Feb 13, 2007 | 07:03 AM
yep
Old Feb 13, 2007 | 09:53 AM
Blue1989RS's Avatar
Car: 1989 RS
Did you get the cold start injector unplugged???
Old Feb 13, 2007 | 01:03 PM
pairtoe's Avatar
would that be towards the front??
Old Feb 13, 2007 | 01:23 PM
pairtoe's Avatar
i just tryed to pry it up with a long screw driver, i put it under the middle of the fuel rail and pryed against the lower manifold and i put some elbow grease into and it started to move, then i heard something crunching and i didnt know if it was a injector, or what. but i stoped. i have every thing off of the fuel rail its self so i dont know what could be holding it down.
Old Feb 13, 2007 | 01:37 PM
pairtoe's Avatar
FINALLY!!! i got a crow bar and wrapped a cloth around it and slowly and gently pryed it un then the fule injectsr broke free and it came right out. and the crunching i was hearing was all the little plastic air hose things that go from the back of the throttle body to the fuel presure regulator, they just got brittle and snappped.
what are those little air hoses called, im gonna have to go down to napa and buy some now.
Old Feb 13, 2007 | 01:43 PM
Blue1989RS's Avatar
Car: 1989 RS
they are hard vacuum lines. I can't seem to find them new. If they aren't broken too bad, you can use heat shrink to stick them back together. Are the injector o-rings destroyed too?
Old Feb 13, 2007 | 03:23 PM
pairtoe's Avatar
a couple got strectched out pretty bad, i probally replace them. but i need all new hard vaccum lines now. probally have to get them at the bone-yard.
Old Feb 22, 2007 | 11:15 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hi,
I put "Mentholatum" in the new injectors o-rings and... in one wiiiiiiiisssshhhh! : Fuel rail with injectors ready and assembled in position!
Regards,
Denis V.
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
3rdgenparts
Aug 8, 2015 07:09 PM
92projectcamaro
Aug 6, 2015 01:20 PM
