headers
Old Feb 18, 2007 | 03:01 PM
rsfmash's Avatar
headers
Will 2.8L v6 headers work on a 3.1L v6?
Old Feb 18, 2007 | 03:20 PM
norcal_balla510's Avatar
Car: 90 RS Camaro
Engine: v6 3.1
Transmission: auto
Axle/Gears: stock
https://www.thirdgen.org/forums/v6/4...2-8-3-1-a.html
that was about 10 threads down. use search
Old Feb 18, 2007 | 07:00 PM
firstfirebird's Avatar
I was going to say the same. Actually it's a question that is asked often.
Old Feb 19, 2007 | 01:22 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
2.8 headers on a 3.1 in California
From what I have been told, while a 3.1 is just a stroked 2.8 and the headers bolt up the same, the smog plumbing is the problem.
Has anyone written a tech article on modding the 2.8 pacesetters for the 3.1 application to make them California smog legal?
Old Feb 19, 2007 | 04:40 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
just convert to the 2.8 smog system. (or if not in CA) dithc the smog system as it is probably broken anyway.
Old Feb 23, 2007 | 07:50 PM
micktroup's Avatar
Engine: 5.7L V8
Transmission: auto
How do you 'switch to the 2.8 smog system'? And is that still smog legal?
Old Feb 23, 2007 | 08:19 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
As long as you transplant the WHOLE smog setup and everything works and what not its still legal i belive. But i live in Kansas so thats just from what i have heard and read LOL.
Old Feb 23, 2007 | 08:25 PM
Xophertony's Avatar
Axle/Gears: n/a
step one:
attain parts from the 2.8s smog system. the smog pump, the hard lines for the AIR system, the manifold AIR tubes, all vaccume lines and all wiring (should not be much)
step two:
put it in your car. this may involve converting your serpentine car to Vbelt.
one thing to consider. get the 2.8 header tubes, weld them shut on the inside (so they do not function) and put them on. then run a tube behind the engine where it cannot be seen and just tell them it is hooked up.
is this legal?
even if you modified the 3.1 system to work with the headers the headers have a CARB# for a 2.8 only, so no matter what you do NO IT IS NOT LEGAL.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
