Cold Air Intake sensor
Old Mar 4, 2007 | 10:35 PM
Benthefrench's Avatar
Car: 89 Firebird
Engine: V6 2.8L
Transmission: Automatic
Hi,
Today i just put a new air-intake on my V6 2.8.
I know what to do with the sensor how was in the box with the old air filter.
But i dont know what to do with this on :
The plug in the hood :
Cen anybody help me ?
Thx
-Ben
Old Mar 4, 2007 | 10:44 PM
TON*LOC's Avatar
Car: 1987 firebird trans am
Transmission: 5 speed
Axle/Gears: 4th 10 bolt hope fully it last
just cut the little metel band that holds the sensor on the on the stock filter canester. then clamp the high flow filter there instead. then cut your intake about 6-8 inches shorter. then just coupler the maf to the tubing
Old Mar 4, 2007 | 10:48 PM
Car: 89 Firebird
Engine: V6 2.8L
Thx man
But what is this sensor ? What it do ?
Thx
Old Mar 4, 2007 | 10:52 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Cold air intake sensor? Is that like a sensor that detects whether you have a cold air intake installed?
That is your mass airflow sensor. It monitors how much air is going into the engine so that the ecu can calculate how much fuel to give it. If you remove it, the engine will not run as nice and your SES light will come on.
Old Mar 4, 2007 | 10:57 PM
Car: 89 Firebird
Engine: V6 2.8L
loool yeah my title was stupid
OK so yeah i need to put it back...
I have to cut my chrome pipe that suck
There is not an other way to put it back ?
cause i cant use my configuration :
Old Mar 5, 2007 | 03:20 PM
Car: 89 Firebird
Engine: V6 2.8L
No ?
Anyway to do it ?
Old Mar 5, 2007 | 03:40 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
remove the section of chrome pipe that I boxed in yellow and do as suggested above by putting it here.
Only other thing that I THINK might be an option would be to convert to Speed Density, but if it would even work I really don't think it is a viable option after you by the parts needed.
Just outta curiosity, did you originally have the dual snorkel intake that went over your upper rad support? I ask as that same snorkel feeds the 5.0 and 5.7 just fine, and it draws air from in front of your rad so it already is a cold air setup. More so than yours now is. heck with a couple PVC elbows you can make it a cold air / ram air setup pretty easy.
Old Mar 5, 2007 | 04:01 PM
Car: 89 Firebird
Engine: V6 2.8L
Thx for your reply man.
No i dont have a snorkel intake originally. I just have the basic stock one.
And i get this chrom pipe for free a while ago and i dont like wasting lool
But ok i will cut it
Mhhh but its look ike the wires are going to be to shorts now...
i need an extention ?
Old Mar 5, 2007 | 04:47 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
He has a bird, they didnt get the camaro intake setup cause of the slope of the hood did not allow for the intake to fit.
Old Mar 5, 2007 | 05:57 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Axle/Gears: n/a
IMPORTANT!!!
the MAF (mass airflow sensor) is a resistance curcuit. when you splice in extra wire to strech out your plug BE SURE it is the same guage. also be sure that when you strip the wires no little bits of wire come off. if you loose even a few copper strands that can effect the resistance of the curcuit and make your MAF read wrong. some people even go so far as to melt the wire insulation off with a lighter instead of trying to use wire strippers.
also if you live in an area with little rain you canaleave your chrome alone. just cut a hole in that bettery tray and drop the filter down through it, then slap the MAF between the filter and tha chrome.
if you live in a wet climate i would not recomend this as the water tends to ruin the MAFs. if you still want to cut the chrome you can always use a T/A TPI piece for the MAF and have it mount to the upper radiator support. see attached image.
Old Mar 6, 2007 | 12:44 AM
Car: 89 Firebird
Engine: V6 2.8L
Ok. there is an update
I change my comfiguration to include the MAF sensor just after the filter.
And there is some artistic pics :
Old Mar 6, 2007 | 10:09 AM
92Birdofprey's Avatar
Car: 92 Firebird
Engine: 3.1
Axle/Gears: stock, dynomax turbo exhaust
all that drilling is not for me. Hey what do you think about this air intake? They say that its a direct bolt on, should I trust or try to make my own? Keep in mind that I'm really bad with the whole drilling and cutting part.http://cgi.ebay.com/ebaymotors/PONTI...QQcmdZViewItem
Old Mar 6, 2007 | 10:15 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
[IMG]http://img237.imageshack.us/img237/9143/dscn0320aw8.jpg[/IMG
Since when does art consist of tilted cameras and out of focus closeups?
Old Mar 6, 2007 | 12:20 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
1st, I notice you are in Cali. If you get pulled over with that on, your screwed. They will also not pass you on smog test with that.
2nd, most of the cheaper "performance" items on ebay are a joke. They sell the same part for most/all of the same cars. A true direct bolt on for your car is non existant. If it did exist, it would be fairly expensive.
3rd, Look at the design. How is that sucking in cold air? It doesnt. Its sucking in hot engine bay air. That is more of a "ram" intake that just removes most of the restrictions.
You could have built a similar system for the same price or less from home depot or lowes like many here have. Sorry to bust any bubbles and sound like a mean ***, I'm not. Just giving you like you asked.
Old Mar 6, 2007 | 03:38 PM
Car: 89 Firebird
Engine: V6 2.8L
Im kinda agree with all of that.
But a Ram Air hood + Air box = $900
My air intake = $50
My list for this car will be :
-Rims or paints the stock one in black
-Drop it 1-1.5 Inchs
-Ram Air Hood + Air box
-GTA rear spoiler
-Paint job (Black)
Then Probably a Strocker kit or if i can find help a Turbo
Old Mar 9, 2007 | 03:22 PM
Car: 92 Firebird
Engine: 3.1
cold feet
I have yet to buy this item, and the only reason I am waiting is to see if anyone knows about it, because when you look at the ebay site, if you look at the comments, it is highly recommended, but it does look a little fishy, and the passing a smog test, I really don't know about that, how can you tell that the setup does not suck up cold air?
Old Mar 9, 2007 | 03:28 PM
Xophertony's Avatar
Axle/Gears: n/a
the "gas pill" and the tornado are also highly recomended... but they don't do a damn thing.
just mae your own. home depot will cut the PVC for you if you ask real nice. i can even give you dimensions from mine if you like. it's real easy to make. plus then it is black instead of screwy looking chrome that is going to rusty over inside of a year.
Old Mar 9, 2007 | 04:57 PM
SouLTeRRoR's Avatar
I have a pretty similar set up. I still have to get ride of the box and **** though.
Old Mar 9, 2007 | 05:03 PM
Xophertony's Avatar
Axle/Gears: n/a
soul terror:
the way that is set up now, you have gained almost nothing from stock. it could cost you 15$ or less to switch over to the "home depot" style like I have
Old Mar 9, 2007 | 05:31 PM
SouLTeRRoR's Avatar
Ya, I just havn't got around to it yet. I just threw it on there cause when I had just purchased the car and was just replacing things. That's 1 of the mods I plan on doing this spring.
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
