reset timing to stock
Old Mar 26, 2007 | 12:33 PM
camaro2.8173's Avatar
ok, i did a search and i found one of the tech articles on how to adjust or chabnge the timming, bu how do i reset it and then adjust it from there.
my car now, i just changed the cam about 1 hour ago, and now the first piston is in TDC and the cam sprocket and crank sproket are both lined up and the niw chain is on. so is that it? is my timming now reset?
where should my rotor be pointing? right now it is at about 4 o'clock? thanks for the help. i explained the best i could.
Old Mar 26, 2007 | 11:11 PM
tigereye7032003's Avatar
Re: reset timing to stock
I know its a real pain in the *** when i changed mine it took us a couple of tried but that had alot to do with the fact that it was are first time. first you want to make sure u losen the distributor a little make sure your marks on the cam sprocket and the crank are point to each other (that was one mistake we made we faced them apart) put everything together then you will have to fine tune the timeing by twisting the distributor a little each way. I know its a v6 2.8 the time should be set stock to 10 btdc if its a v8 its 0 degrees. hope that helps.
Old Mar 27, 2007 | 10:18 AM
ok, well if the first piston is in TDC, and the timming sprocket and crank sprocket are both in the right position pointing towards each other, then where does the rotor on the distributor have to be poiting at?
its a 2.8
Old Mar 27, 2007 | 08:26 PM
91_rs-teal's Avatar
Car: 1991 Camaro, Best 12.40 @ 115.8 MPH
Engine: LS1, HCI, Headers
Transmission: T56, Monster Stg. 4
Axle/Gears: 7.5" 10 Bolt - 3.73's w/ posi
easy way is put wires were there suppost to go and point rotor to #1 cyl on cap
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
camaro71633
Sep 1, 2015 10:24 AM
Thirim
Aug 9, 2015 06:19 PM
