02 sensor
Re: 02 sensor
If it's like mine, the purple wire goes from the o2 to a single wire plug just behind/under the pass side head, that in turn goes to a "y" in the harness a little further up. From there it goes back to your ECM. I can look when it's light out and tell you the other color wires in the "y". If need be you could run a new one to the ECM.
Was the wire cut near the sensor, or after the connector?
Car: 1998 Camaro Z28
Engine: 6.0L
Re: 02 sensor
so theres no wire coming off the o2? do you have a check engine light on or a code for the o2?
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: 02 sensor
Our cars are stupid when it comes to the O2 sensor. I've seen some that never set a code for an unplugged O2 and others that are super **** about it.
It's kind of ironic because our cars are pretty advanced for their time as far as self diagnostic and data streams go.
Car: 1990 Firebird
Engine: 3.1....4159265
Axle/Gears: axle rose and metal gear solid
Re: 02 sensor
Hello Instead of there being an oxygen sensor in my exhaust tube there is just a plug there with a hex socket what do I do now why doesnt it have a oxygen sensor?
90 firebird 3.1
90 firebird 3.1
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: 02 sensor
You should have an O2 sensor and have an SES light. I would get one and try to find the connection.
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Re: 02 sensor
Mine would not set a code for O2 either the wire was cut and burned. My gas milage was horrable 10 mpg. My collant temp sensor was broken. Previous owner did a number on car. After replacement of that I started getting code for o2. Fixed wiring and then got MPG 20-25.
Car: 89 V6 Camaro
Engine: 2.8
Re: 02 sensor
Does anyone have a problem with their O2 getting coated in soot? Mine will get coated in less than a day and won't function properly. I am running 3.1 injectors in a 2.8. I am running a little rich but not much. Any way to fix this problem?
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
Re: 02 sensor
does anyone have a picture of where the o2 sensor wire connector is? ive spent an hour looking for it and i didnt see a purple wire. my camaros running really rough because the people who put in a new exhaust didnt put in an o2 sensor and plugged the hole for it.
Re: 02 sensor
nvm i found it, the plug was along the bottom behind the engine
Car: 89 RS
Engine: 2.8
Re: 02 sensor
Car: 1988 Camaro RS
Axle/Gears: 3.42's
HoosierinWA
Oct 7, 2015 10:15 AM
You should be getting codes.
