question about heads
Old Apr 7, 2007 | 09:51 AM
blindreaper1226's Avatar
Car: 88 Camaro SC
I have a 88 2.8l engine. I'm wondering what I can do to the heads. Are there any other heads that will fit, from like a 3.1 or 3.4 v6 or could I port the heads I have now.
Old Apr 7, 2007 | 12:18 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: question about heads
The fuel injection heads from 87-92 S-10 and f-car 2.8's or 3.1's, 86 and up fiero or the 93-95 f-car 3.4 engines are the same and are listed as the best stock heads for your application. As long as the engine was fuel injected in those years they would be a great find for a junkyard pull and your first upgrade for your engine after porting.
Old Apr 7, 2007 | 02:44 PM
firstfirebird's Avatar
If you do a search on redraif, she has a MyCarDomain page with some really nice pics of the wild port job done she did on her 60* V6.
Old Apr 7, 2007 | 10:24 PM
Car: 88 Camaro SC
thanks for the input about a month ago I seen a fouth gen camaro in the junk yard hopefully it still has the heads on it. From there ill have to find that girls page I need to learn how to port the heads any info on porting heads will be much appreciated links to sites also if you have them will help me out a lot. thanks
Old Apr 7, 2007 | 11:33 PM
daves12secV6's Avatar
blind ill get u some pics of a ported set, and maybe i can label them to help explain what to grind for u. its not all that hard to do,but u do have to take ur time and be carefull.
Old Apr 8, 2007 | 01:53 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
could you possibly send those pics to me also? email is snipersracing@gmail.com. Thanks!!!
Old Apr 8, 2007 | 04:51 PM
Car: 88 Camaro SC
Thanks dave that would help me out a lot. my email is blindreaper1226@cs.com you can send them there or post here either way is fine. By the way I'm really interested in that turbo you have hooked up looks like fun to build.
Old Apr 9, 2007 | 07:41 PM
Car: 88 Camaro SC
I hit the junk yards today. The fourth gen I seen a while ago was completly gone. The other 2 yards I went to only had 3rd gens. I did get some black door pulls and a gage face plate for 5 bucks thow. Well after that I called a junk yard where they pull all the parts for you, and they priced them at 150 a pair for the aluminum 3.4l heads. What do you think guys good deal?
Old Apr 9, 2007 | 08:35 PM
stock
Old Apr 9, 2007 | 08:37 PM
mildly worked
since i dont have a camera right now i can take pics of the heads i just did for pairtoe, but if u ask nicely and he has a camera maybe he will post pics of them for u once he gets them on wensday.
i did a much more thourogh job on his,the ones i have pictured above was a basic cleanup/light work on the intake sides
Old Apr 9, 2007 | 08:48 PM
No, I got mine off e-bay for $25 (shipping was $40 though). Just have to be patient and watch.
Old Apr 10, 2007 | 08:51 AM
Car: 88 Camaro SC
Yeah I wasn't sure but 150 sounded like too much for a junkyard set. If I could find them at U Pull It they would be 10 times cheaper. I,ll be patient so I can save some cash.
Thanks for the pictures dave they help alot what kind of tool would I use to port the heads? A dremel.
Old Apr 10, 2007 | 08:54 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
I also don't think that the aluminum heads are for your car. I think just the cast iron heads fit your car. I could be wrong...
I have a set of 2.8 heads from an 88 S-10. If you're interested let me know. They would ship from north western Ohio so it wouldn't be free...
Old Apr 10, 2007 | 09:36 PM
The aluminum heads will fit, but would produce a high compression ratio, and the intake manifold for the iron heads won't work.
Old Apr 10, 2007 | 10:01 PM
Car: 88 Camaro SC
So your saying that if I pull aluminum heads off a 93 to 95 fourth gen 3.4l v6 then I'll have to replace the manifold to fit them...
Old Apr 10, 2007 | 10:04 PM
And also the cylinders, unless you are going to use race gas .
EDIT, If it's a 4th gen f-body, what aluminum heads? I don't know if the 3800 had aluminum heads, but the 3.8 headswill not fit at all.
Old Apr 10, 2007 | 10:08 PM
Car: 88 Camaro SC
so whats my best bet here. Should i just port & polish a pair of 2.8 iron heads?
Old Apr 10, 2007 | 10:10 PM
Then you could just bolt them on.
Old Apr 10, 2007 | 10:43 PM
Car: 88 Camaro SC
I'm assuming they do have aluminum heads. I called a parts yard and asked for a set of 3.4l v6 camaro aluminum cylinder heads. The guy said he had a pair and they will fit the 2.8/3.1/and 3.4 blocks. I'm getting so confused on what to do right now..nothing has to be done this moment, I just dont want to fall off on this project. ya know well any input is much appreciated thanks for taking the time to help me out
Old Apr 11, 2007 | 08:38 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
I don't think fourth gen heads are aluminum; cast iron, and the same as later (87 and newer) 2.8/3.1/3.4.
Any of these heads should be the same so get a set from any of the above mentioned cars (even the fiero) and work them over in your garage. Then put 'em on when you have time.
Aluminum heads were used on front wheel drive 2.8 and larger 60* V6 engines but use a different intake that isn't "plug and play" with a third gen. The fiero intake will work, though (on cast iron heads, I mean.)
Old Apr 11, 2007 | 09:47 PM
Car: 88 Camaro SC
Ok heres my plan. Tommorow I'll go to U Pull It they have a fiero up there I'll take the intake/throttle body and possibly the heads for practice. (You meant that the fiero intake will bolt up to the aluminum heads correct? Just want to be sure.)
Old Apr 11, 2007 | 10:40 PM
Fiero intake will NOT fit the aluminum heads. If you want aluminum heads you are going to have to take the entire top end (even the fuel rail) and pistons. You will probably have to reconfigure your accessory drive. Then there is the distributor issue. If you have a 2.8, you will need to take the crank. Do some searching on hybrid 60 degree engines and that is what they mean, a FWD top end on a RWD bottom end.
Old Apr 11, 2007 | 10:45 PM
Car: 88 Camaro SC
Ok i got ya. I'm just gunna go ported iron heads.
Old Apr 12, 2007 | 10:07 AM
pairtoe's Avatar
yeah dave ported/polished my heads(plus a few other goodies), i should get them in the mail this afternoon sometime and if i can get my digi cam to work i will post up some pics later. but so far from some of the stuff ive seen him make i have no doubt they came out good.
Old Apr 12, 2007 | 02:42 PM
He (Dave) modified my intercooler .
Old Apr 12, 2007 | 03:08 PM
pairtoe's Avatar
he should put out a brand on everything he makes,
daves racing products
but yeah i got my heads back from him and they are awesome. they are really opended up know, cant wait to test them out.
Old Apr 12, 2007 | 10:51 PM
Car: 88 Camaro SC
What size engine do you have 2.8?
Old Apr 12, 2007 | 11:05 PM
pairtoe's Avatar
yeah its a 2.8
Old Apr 13, 2007 | 12:24 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
GenIII 660 heads (3100/3400) are completly worth the extra effort. No matter how much you port the genI (iron head) heads, they will not flow as much as the genIII heads in stock form. Reasons being: Riased port design, splayed valves for better flow and better unshrouding of the valves, better design for overall port shape.
I'd do the top end swap again in a heart beat.
Old Apr 13, 2007 | 08:21 AM
Car: 88 Camaro SC
what did you have to do for the top end swap?
Old Apr 13, 2007 | 08:37 AM
pairtoe's Avatar
what is the reason you are looking to port the heads anyways? just to learn?
Old Apr 13, 2007 | 10:07 AM
Car: 88 Camaro SC
yeah basically and to be able to do sumthing to my engine myself.. I dunno i've been doing some resaerch arround here and the 3.4 swap sounds like somthing that would work out good for me. My camaro is my daily driver for the time being, how ever it will sit when i go to college in the fall unless i come home on the wekends. If I can find a 3.4 I can work on it in my garage and when I have it finished I can drop it into my current camaro or buy a roller and drop it in there.
Old Apr 13, 2007 | 03:52 PM
pairtoe's Avatar
is the engine in the car now bad?
Old Apr 14, 2007 | 03:50 PM
Car: 88 Camaro SC
no it runs well it nickel and dimes me here and there but for a 18 yr old car it runs good. I had a cat go bad a water pump a thermostat gasket leak an altenator a radiator the interior isnt bad though just needs hatch struts the carpet isn't to bad and most of the plastic is intact or cheap to replace if i were to be **** over it
Old Apr 15, 2007 | 04:34 PM
pairtoe's Avatar
well if it runs fine and isn't taken apart yet i wouldnt do it. just get some cheap junkyards heads and practice on them . but if you are gonna tear your whole motor down just to port your heads your wasting your time. it will be a lot of effort for a little gain.
Old Apr 15, 2007 | 04:43 PM
hey pair did ya get ur motor back together yet ?
Old Apr 15, 2007 | 04:52 PM
pairtoe's Avatar
almost, just need to figure out how to hook up my vaccum and a few plugs hear and there, oh and im waitng on my new pushrods to get here. then im gonna fire her up.
i have a sick picture of it all together and painted, but i cant get it on here cause its on my phone.
Old Apr 15, 2007 | 05:00 PM
email the pic to urself lol dont forget to oil the rockers when u reinstall them
Old Apr 15, 2007 | 05:30 PM
I used assembly lube, and fill your pushrods with oil
Old Apr 15, 2007 | 05:56 PM
lucas oil additive stuff works as a good asembly lube
i have the red torco stuff from the race car i use,
we used the stuff inbetween rounds with the dragster while tearing down/reasembling the motor,after a run that stuff would still be were ever we put it.
Old Apr 16, 2007 | 08:23 AM
pairtoe's Avatar
yeah i was going to just thro on the stock rods and just change them once the new ones came in but i figured i would be patient and just wait two days.
Old Apr 16, 2007 | 08:35 AM
  #42
smart move,otherwise it would have been liek well i got it running these can wait lol. u ever get pics of the heads or the nitrous system?
Old Apr 16, 2007 | 10:16 AM
  #43
pairtoe's Avatar
omg i wanted to slap my self, i was planning on taking pics of the heads the day i got them and i wanted pics of them before i put them on the car, but i kept forgeting and now they are on the car, but the nitrous system i might be able to get the pics of it off ebay, let me look.
EDIT: the bottle is diffrent now, i repainted it the bottome is black like my interior and it fades into viper blue like the exterior. it looks really sharp, to bad its gonna be covered with a bottle heater though.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
