3.1 Transmission Issues/I Think I Broke Something
Old Apr 15, 2007 | 02:43 PM
redline_racing's Avatar
hello,everyone i need help,friday nigh i decided how bad will i get beat when i pull out my 1991 3.1 firebird to the illeagl street races in pa?well bad ideal i was starting to race another bock stock 3.1 camaro and i netural bombed it and then i heard something sound like it unbolted i was scared as hell?so now every time i punch her from a light something under my shifter makes a loud bang i think i broke something on the trans but trans shift smoothly doesn't overheat i just can't take off really fast without hearing the loud bang any help anybody please help ?????????
Old Apr 15, 2007 | 04:21 PM
daves12secV6's Avatar
Re: 3.1 Transmission Issues/I Think I Broke Something
sigh u broke the transmission mount. if u continue to nutral drop that trans u wont have a working transmission for long
Old Apr 15, 2007 | 05:48 PM
firstfirebird's Avatar
Yeah, back when I was 16 I did a lot of neutral drops in my Caprice. One day it would barely go reverse. I had the tranny fluid changed (didn't know much about cars back then lol) and the mechanic handed me a bottle full of teeth from the gears, lmao.
Redline, if you want to have fun doing burnouts, just use your left foot for the brake and floor the gas with your right. Let off the brake slowly and the car will start spinning the rear passanger tire. This way you are only wasting your rubber .
Old Apr 15, 2007 | 06:28 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
and don't forget to replace that tranny mount, ASAP!!!
Old Apr 15, 2007 | 07:07 PM
how hard is the transmission mount to replace also i can burn out for some reason i'm a expert on burning out she just won do it for some reason i think the previous owner put to big of tires on it also i buy these cars and sell them anyone interested? $2500 obo or partial trade cash plus car?
Old Apr 15, 2007 | 07:16 PM
also i looked a transmission mount up and the rand from like $15-40 dollars and you guys shore thats what's making this loud *** noise when i punch it;the piece is all of cd player remote and its causing that big *** sound?thanks rob
Old Apr 15, 2007 | 07:25 PM
HPE's Avatar
HPE
Yes they are sure. What you are doing right now when 'punching it' is tearing the crap out of your car by means of your transmission slamming into your floorboard because the mount is broken. Keep doing it and you'll sell that car for $20
The torque are is mounted to the side of the trans (On factory stock setups) and the upward thrust of that torque arm is what breaks the old, worn, & weak factory trans mount- thus lifting up the entire trans into the trans tunnel and making that o-so-pleasant noise you are dicovering sounds like someone hitting the floorboard with a sledgehammer- Are we clear now?
Old Apr 15, 2007 | 07:31 PM
HUH?
Old Apr 15, 2007 | 08:50 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
hes comparing the trans mount to a car audio cd player remote.
Old Apr 15, 2007 | 09:11 PM
so you are saying its the trans mount or torque am? thanks rob
Old Apr 15, 2007 | 09:27 PM
trans mount
the tq arm mounts to the side of the transmission, when u hit the gas the tq arm lifts up on the back of the trans,which in turn pulls on the trans mount,eventually the forces applied to the trans mount make them break. once they break the tq arm lifts the back of the trans and slams it against the floor, besides the annoying clunk it also changes the angle on the front u joint and can cause it to prematurely wear out if u dont replace the trans mount.
ur lucky u dont have a stick shift car,otherwise ur shifter would be poping up threw the floor whenever u got on the gas
Old Apr 15, 2007 | 09:58 PM
trans mount
so dave your saying its the transmission mount and not the torwue arm? also how hard is it to replace it?thanks rob
Old Apr 15, 2007 | 10:28 PM
91badgreen's Avatar
Car: 91 firebird
Engine: 3.1 v6
yeah sounds like the transmission mount. same thing happend to me except i wasnt nuetral bombing it i just had a crazy girlfriend who decided it would be a good idea to throw my car in reverse when i was going 45. after that the transmission would make that banging sound from a launch. i lost the girlfriend and got the mounts, but then again im not totally sure that throwing the trasmission into reverse was the how thing the guy who owend the car before me could have nuetral bombed the heck out of it for all i know
Old Apr 15, 2007 | 10:44 PM
its easy jack up the car put it on stands, put a floor jack under the trans pan(with a piece of wood on it) jack up enough to catch the wieght of the trans .
take out the bolt for the trans mount then the 4 cross member bolts, remove cross member,then remove the 2 bolts holding the other half of the trans mount to transmission,install new mount i.e put 2 bolts in to hold mount to trans, grab cross member hold it in place,install nut on trans mount,leave lil loose,install 4 bolts to hold cross member in car. lower jack from under trans and then tighten the bolt from the crossmember to trans mount. lower car and ur done
Old Apr 15, 2007 | 10:52 PM
speedracer0626's Avatar
Car: 89 Bird 93 Old Cutlass Ciera
Engine: 305/ 3.8 S.C.
Transmission: 700r4 and IDK
Axle/Gears: ????????
I was with my friend and he had a 383 2200 stall with the 700r4 stock trans mount. Man when it broke you should have seen that torque arm almost launched the rearend out of it needless to say it can hurt did scare the sh@# out of me. Or just go ahead and nuetral bomb it till it gives
Old Apr 16, 2007 | 12:16 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
.... n/m
Old Apr 16, 2007 | 06:13 PM
I got it fixed thanks you guys for the help but i think im let my f-body go 1991 firebird 3.1 nice all around new tires great on gas asking $2500 obo has 142k oil changes every 2k?anybody interested
Old Apr 16, 2007 | 11:36 PM
HPE's Avatar
HPE
Hey everybody, great car, takes care of it, oil changes every 2K, etc... Plus he Neutral drops it.. what a steal for $2500.
Go insult someone else
Some people are so naive they just don't see how blantantly stupid they are. The pperson that buys that wreck will being laying out 3k for a new trans install the next week- and god knows what else will fall apoart that we do not know was abused also.
Old Apr 17, 2007 | 12:46 AM
lol i was gonna reply when he posted that but i just kept my mouth shut
Old Apr 17, 2007 | 11:33 AM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
I think we can all see the negatives of inbreeding here.
Old Apr 17, 2007 | 04:44 PM
Somebody is not playing nice in the sandbox. lol.
Old Apr 17, 2007 | 05:27 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
I agree that $2500 is way too much, but dont you think that this kind of response in unnessesary? Couldnt you just have said that that is way too high of a price?
Drop $1000 off that price and you would be closer to a good price for that car.
Old Apr 17, 2007 | 06:28 PM
HPE's Avatar
HPE
No.. he insulted my intellegence and should have done so to you also. People don't like that I just speak things how I see them. I don't take kindly to someone typing on a public forum assuming we are stupid- He needs to be put into his place. I did that- It was not an attack, iot was a response to his dishonesty. Well taken care of my ****.
Its always this younger V6 crowd that was raised so g()d damn politically correct and always seem to have a problem with me. Every problem I have ever had on this board starts here- grow a backbone people.
Old Apr 17, 2007 | 06:36 PM
HPE's Avatar
HPE
I come iback into here seeing 4 response indirectly directed towards me like I'm the *******. Got news for youguys, Good ol Dave here at least 'thought' the same thing I did, But because he didn't have the backbone to just come out and say somerthing makes him better than me? Someone doesn;t give you back the proper change in a store and you say nothing either? Whats the deal around here.Always the V6 board.
Old Apr 17, 2007 | 06:42 PM
see I would stoop to your little level but you know what,since your level so low ask your women how it feels to be with a man like me instead of little boys that leaves stupid comments if your not interested in the car don't say nothing and keep moving (HPE-DAVES)GOOD DAY LADIES!
NOW I'M INSULTING YOUR PRIDE! ///////
Last edited by redline_racing; Apr 17, 2007 at 06:44 PM. Reason: Automerged Doublepost
Old Apr 17, 2007 | 06:46 PM
I never said it was you specifically, Dean . Do you have a guilty conscience?
Don't you think inbreed is as negative as stupid? Not everyone has an education in automotives. Can you tell me that you never did something (that may have been stupid)in your car that you regreted later?
I agree that it wasn't a good idea to sell a car in a place where you just told everybody how you trashed it.
Old Apr 17, 2007 | 06:57 PM
I agree bad move but I dont burry my car like some people does all I do is buy f-body's and sell them I deal with honesty when sell my cars. Thanks for comming to defense?
Old Apr 17, 2007 | 07:01 PM
grimmcs's Avatar
Car: 91 Camaro
So what is done to your car that makes it a $2500 car?
Old Apr 17, 2007 | 07:04 PM
I'm not going to defend you. If you are honest about the cars you sell, then are you going to tell the buyer that you had to replace the tranny x-member because you were neutral dropping it? I agree with the other guys that it was a bad move, and you are asking too much. I just got mine in Aug or Sept for $2600 with less than 2/3's the miles yours has, and in near mint condition. In fact I was really impressed that it appeared my car had never been jacked up (at least not by the stock jack in the stock locations), and still has the origional window sticker and owners manual.
Old Apr 17, 2007 | 07:20 PM
Well you know what I was asking for what what I wanted for the car if you guys arent interested dont say nothing at all keep all the negative comments to your self I don't need hate'n a(ss people to tell me what to do and what to ask and great for you that you got one for for $2600 dont you need a pat on your back great for you so when your ready to race me with your 3.1 put against my 84 regal 455 and see your near mint get dogged and be just like mine i was being cool not no more!!!!!!!!1
aint sugar honey ice tea doe to eat i done it before on ebay with a ******* car so thanks!!!!!!!!!
Last edited by redline_racing; Apr 17, 2007 at 07:23 PM. Reason: Automerged Doublepost
Old Apr 17, 2007 | 07:28 PM
Woohoo, a 455 beating a 3.1, do you think that is proving something?
Besides if you neutral drop with that car, I'll definately smoke you while you are picking up the peices, lol.
I guess you were right Dean, I'm get tired of these childish conversations that have nothing to do with the origional question.
Old Apr 17, 2007 | 07:35 PM
Old Apr 17, 2007 | 07:40 PM
you and dave go and F%$k yourself??????
Old Apr 17, 2007 | 07:47 PM
Well you are welcome for identifying your problem and this post has been reported.
If you read my past posts, you will see that I do everything I can to keep peace and help people out, good luck and welcome to my ignore list!
Old Apr 17, 2007 | 07:58 PM
lmao and i didnt do anything but tell u how to replace ur mount
kids these days lmao
post reported x2
Old Apr 17, 2007 | 08:01 PM
I reported please dont get the thirdgen po-po's come after me dont care peace to you guys i'll be back underneath a different email homo's
Old Apr 17, 2007 | 08:02 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Old Apr 17, 2007 | 08:05 PM
OH YEAH DAVE SORRY I THOUGHT YOU SAID SOMETHING IGNORANT I'M SORRY IM A MAN ABOUT MINES AND I'M DEEPLY SORRY BUT FOR THE OTHER A(SS HOLE FOUR FINGERS 1 LEFT UP REPORT THAT
Old Apr 17, 2007 | 08:10 PM
Intellegence in the making, I'm a homo with a wife and four kids.
Is what I find amusing is that he is almost the same age as you, Dave!
And as far as that po-po's (as you say), I vote for your ip to get banned also!
Old Apr 17, 2007 | 08:20 PM
Engine: 3.1
Dean, the Inbreeding comment was based towards the starter of this post, not you. I think he's completely proven himself to be either a 16 year old kid, or just a flat out idiot.
Old Apr 17, 2007 | 08:22 PM
grimmcs's Avatar
Car: 91 Camaro
What the hell does that mean, besides admitting that you con people?
Old Apr 17, 2007 | 08:39 PM
  #42
I dont con nobody jack *** report me ****ing you up
Old Apr 17, 2007 | 08:48 PM
  #43
first lmfao i took him for some 17-18yo kid
guys just put him on ur iignore list and stop replying to him/this thread
Old Apr 17, 2007 | 08:49 PM
  #44
Engine: 3.1
Why can't you type and talk like a normal person? Maybe this wouldn't be happening. God damn, wish we had a moderator.
guys just put him on ur iignore list and stop replying to him/this thread.
:ban:
Dave for moderator 07.
Last edited by noahTHEpurdy; Apr 17, 2007 at 08:50 PM. Reason: Automerged Doublepost
Old Apr 17, 2007 | 08:54 PM
  #45
NaNaNa-Boo-Boo. =P
Old Apr 17, 2007 | 08:56 PM
  #46
incase u guys havent noticed we did get a new moderator
Old Apr 17, 2007 | 08:58 PM
  #47
HPE is Dean, I'm john, and I realized who the comment was directed at - just wasn't very PC.
I guess we still need another one who is online more often, this thread should have been stopped a long time ago! Dave you up for it?
Last edited by firstfirebird; Apr 17, 2007 at 09:02 PM. Reason: Automerged Doublepost
Old Apr 17, 2007 | 09:06 PM
  #48
u know i would be,but i would rather it go to somone else(six_shooter).and i highly doubt we woudl get another mod added,i had been trying to get a mod for this section for the longest time,and finally after getting u guys to pm jt we finally got a new one
Old Apr 17, 2007 | 09:43 PM
  #49
ok I'm sorry you guys !!!!!!!!!!!!!!
hi dave just to say sorry but don't let me catch you we will have a deep stimulating convo in the parking lot ! shots rang u fall i run end of story
Last edited by redline_racing; Apr 17, 2007 at 09:47 PM. Reason: Automerged Doublepost
Old Apr 17, 2007 | 10:01 PM
  #50
BAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
