doesnt start
Old Apr 17, 2007 | 02:05 PM
xiholdtruex's Avatar
Car: 88 prelude si/91 camaro rs
Engine: 2.0/3.1
Transmission: D2J5/700r4
doesnt start
my car does not want to start any idea what it can be?
Old Apr 17, 2007 | 02:23 PM
tnt_viper's Avatar
Car: 89 Camaro RS, 99 Sunfire GT
Engine: 2.8L, 2.4L
Re: doesnt start
when turn the key what happens? does it turn over? does it make a click sound? Does it go click once or alot of times? Does it make no sound at all? You're going to have to tell us a little more details for us to help you.
Old Apr 17, 2007 | 10:58 PM
Engine: 2.0/3.1
Re: doesnt start
we'll my car turns over and slowly stops. and does not turn on when its been drivin for a while.also i was trying to start it and it caught fire today. i dont know why it caught fire but i have to check that out.
Old Apr 17, 2007 | 11:02 PM
tnt_viper's Avatar
Engine: 2.8L, 2.4L
Re: doesnt start
from where did it caught fire? and what year is it?
So does your car start or not, since you say that after it's been drivin it does not run?
I'm getting confused
Old Apr 17, 2007 | 11:06 PM
Engine: 2.0/3.1
Re: doesnt start
i have a 3.1 liter engine,it caught fire in the engine bay next to where the ignition coil and starter are.right now it does not turn on at all but when it did after it was drivin for a while if you turned if off it would not turn back on.
Old Apr 17, 2007 | 11:12 PM
tnt_viper's Avatar
Engine: 2.8L, 2.4L
Re: doesnt start
you could of burned the power wire for your starter be trying to start it so much, it overheated and POUF!
Usualy when I see a car that does not start when the engine is hot, it's the fuel pressure regulator.
things I would do if I was you is
1.check the battery voltage
if thats good...
2.check for spark
if thats good
3.check fuel pressure
I'm sure in one of those there will be your problem, is you get no spark, you know it's an igintion problem, and it will help narrow down results. But now you got that little fire problem, I hope the wire, or the starter solenoid is not f#@$ed
Old Apr 17, 2007 | 11:22 PM
Engine: 2.0/3.1
Re: doesnt start
thanks for the suggestions i will update on this once i check all of that.
Old Apr 18, 2007 | 01:38 PM
Engine: 2.0/3.1
Re: doesnt start
checked the starter its fine all the cables a solonoid are intact and fine,changed the battery,car turns over but still no start.
Old Apr 18, 2007 | 02:01 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: doesnt start
narrow it down.
Does the fuel pump prime?
Does the car spark?
All fuses good?
Do you have power to all the accessories ?
Old Apr 18, 2007 | 02:04 PM
Engine: 2.0/3.1
Re: doesnt start
fuel pump primes,spark plugs spark
fuses good,and i have power to everything else
you think its the fuel pressure regulator????
Last edited by xiholdtruex; Apr 18, 2007 at 02:05 PM. Reason: Automerged Doublepost
Old Apr 18, 2007 | 02:23 PM
j dezzy's Avatar
Car: 87 TA
Re: doesnt start
I had a car that wouldn't start after being run for awhile. turned out that the starter solenoid was bad.
Old Apr 18, 2007 | 02:38 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: doesnt start
OK, let's start over...
You say the car will turn over, but does not start. Meaning the starter circuit is ok and the motor spins, but it won't run.
What exactly caught fire? What is burned? Any wiring?
Has it run since you got the car or did you buy it not running?
How long has it been since it ran?
To try and diag a car over the internet, we need fairly detailed information.
Old Apr 18, 2007 | 03:49 PM
Engine: 2.0/3.1
Re: doesnt start
update...checked my spark plugs again today i thought they were ok but there busted to hell black and rusted currently changing lets see if it starts. also nothing burned i checked it out today.the only thing that still has not changed for sure is that after a while of driving it it doesnt want to turn on. and it has been around like a month and a couple of weeks i have not turned it on.
Old Apr 18, 2007 | 09:27 PM
Engine: 2.0/3.1
Re: doesnt start
changed spark plugs,changed battery....it turned out my starter solonoid is gone i hit it a couple of time and it started up going to change it next week hopefully thats the end of my problems with it.thanks for everyones help its much appreciated.
Old Apr 18, 2007 | 10:17 PM
j dezzy's Avatar
Car: 87 TA
Re: doesnt start
I've had so many bad starter solenoids in newly purchased cars it's not funny. I hate pulling the starter out of cars.
Old Apr 19, 2007 | 12:04 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Re: doesnt start
note: with our cars... you can take the solenoid out WITHOUT taking off the starter... there are only 2 screws, take it out just like you see it in the box... and put the new one on. TRUST ME!!!! DO NOT TAKE OFF THE STARTER, ITS A PAIN AND VERY HEAVY. k? k. good. hehe
Old Apr 19, 2007 | 09:07 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Re: doesnt start
Originally Posted by xiholdtruex
...hopefully thats the end of my problems with it.
Trust me, you'll never see the end of your problems with an older car...it'll just be something new.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
