Finally got the entire 3400 upper
Old May 5, 2007 | 06:17 PM
firstfirebird's Avatar
Here are some pics...
Old May 5, 2007 | 06:37 PM
pairtoe's Avatar
Re: Finally got the entire 3400 upper
holy **** thoose are dirty! so now you need a new engine i take it? are you putting in a 3.4, or just top end of a 3.4
Old May 5, 2007 | 07:23 PM
HAHA, those are some heads I got for free. The aluminum heads are from a FWD. I will have to chage pistons, unless I want a 11.78:1 compression. These are for the next motor...
Old May 5, 2007 | 07:31 PM
pairtoe's Avatar
so what are the plans for the new motor? or is it top secret???
Old May 6, 2007 | 06:38 AM
No secret, just a hybrid.
Old Jun 7, 2007 | 08:26 PM
Well it's been a while, but I think I found a 3.4 to help with the DIS situation (couple of cubes to boot, too ).
Weighed the iron upper for someone here and it came in at a whopping 81lbs whereas the aluminum weighs 45lbs. Actual installed will vary slightly since the aluminum upper had the fuel rail included and the iron upper had the plenum included.
Old Jun 8, 2007 | 03:24 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
You'll be happier with the 3.4. Get it.
Old Jul 6, 2007 | 07:05 AM
New update...
Well, I scored a 3500 upper for a good price (figures just after I bought an upper plenum/manifold for the 3400 upper end.
I guess these could be for sale, since the 3500 heads will fit on a 3.4. If anyone is interested, I also have the FWD deep pistons to go with it. I would rather not part it out, but sell it as a kit.
Old Jul 25, 2007 | 08:28 AM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
i dont git it
Old Jul 25, 2007 | 09:42 AM
Originally Posted by 92camarorv6
i dont git it
15-30hp gain by changing the heads . Look at the difference in the valve angle and the size of the ports.
Old Jul 25, 2007 | 09:01 PM
BaBaBaBaBad-to-the-bone, da-na-na-na-na-na--da--na--da--na.....
Bye-Bye-3400, hellooo 35!
I'll get some good pics of the ports etc tomorrow, I'm not handling these heads after 6 Bud Lights
Old Aug 3, 2007 | 08:10 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
will the hieds work on a 3.1
Old Aug 3, 2007 | 08:56 PM
Not unless you bore .080" over. 3400 heads are the biggest you can go.
Old Oct 20, 2007 | 02:19 PM
brandon_mckay's Avatar
Car: 1988 RS Camaro
Engine: 2.8l/ hopefully boosted 2.8 soon
Transmission: blown up t5
is the 3400 head off of what would be the newer impala motors
Old Oct 20, 2007 | 03:54 PM
Yes, but I went with a 3500/3.4 combination instead...
https://www.thirdgen.org/forums/v6/4...ts-hybrid.html
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
Luigytico09
Oct 1, 2015 08:46 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
