posi-traction question
Car: 1982 FIREBIRD-1983 CAMARO
Engine: 305 LG4
Transmission: TH350-TH200
i am looking to install a positraction to my 1992 v6 RS CAMARO.my car is equiped with the rear drum axle.i know that i must purchase a 8.5 10 bolt posi..but can anyone tell me...how many splines????
Car: check
Engine: check
Transmission: check
Re: posi-traction question
If the rear is stock in the '92, then it has 28 slines axles. Also, it will be a 7 5/8" 10-bolt, not the 8.5".
RBob.
RBob.
Engine: 305 LG4
yes is the factory axle with drum brakes.did the axles slines vary via what engine is the car equiped with?my car has the factory 3.1 v6.
Car: check
Engine: check
Transmission: check
No difference in the splines for an 8 versus a 6 cylinder engine. The only difference between all of the drum brake rears for '92 is the gear ratio and open vs posi.
RBob.
RBob.
Car: 1998 Camaro Z28
Engine: 6.0L
check ebay for an SLP take off, its a zexel torsen limited slip diff. theyre great for the price. i picked mine up for $120 with 2 miles on it.
Engine: 305 LG4
i just purchase this!i think is the best for me!and it is a torsen!TORgue SENsitive!check out the auction below
http://cgi.ebay.com/ebaymotors/ws/eB...4453850&rd=1,1
Engine: 6.0L
actually its an auburn, but still, good pick up, you may need different axle shafts though, check the splines on it.
Engine: 305 LG4
the seller told me that it is a plug n' play for my car and i can keep my gear ratios!so...what can i say?
Engine: 6.0L
since yours is a 92, yours may be a 28 spline axle, i dont remember what year they were swapped. may wanna double check on that so you dont get it ripped apart and then find out you need other axles. but i do believe that yours is a 28 spline.
Engine: 305 LG4
hey guys...can you tell me what lubricant to use in this auburn posi diferential???my car with its factory differential has dexron oil.now with the auburn what can i use so i do not damage it!?
