Rear main seal gone, What would you do?
Old May 25, 2007 | 02:52 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I was thinking my best bet would be to find a 3.4 and switch it in, because a rear main seal is toast on my 2.8. I have to change my clutch, aswell. So I was thinking, since I have to pull my motor, I might as well do a 3.4 swap but finding one in decent condition is an excercise in futility. So what should I do, wait for a 3.4 and swap it out, or fix mine, and then do the 3.4 swap (Kinda pointless, really)?
Old May 26, 2007 | 08:35 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Rear main seal gone, What would you do?
you dont need to pull the engine to do the rear main seal. and if youre replacing the clutch anyway, you have to pull the flywheel, so youre already staring down the rear main seal. all it would be now it popping it out and popping in a new one. so the 3.4, would be up to you really. id say put the 3.4 in though but who dont want more power?
Old May 26, 2007 | 03:15 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I don't know who taught you to put a clutch in, but they ought to know that you pull the TRANS to get the clutch out, NOT the engine. After you pull the clutch assembly off, undo the six bolts holding the flywheel on and pull the RMS (like $10 or so), rather than swapping out the engine (excess of $300), unless, like was said above, you want more power.
Old May 27, 2007 | 11:04 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Been talkin to ricerz I bet.
If the engine is runnin good and not say over 200,000 just fit it.
Old May 28, 2007 | 06:28 AM
Kevman's Avatar
Engine: 2004 LQ4
194500, and she smokes on start up.
Old May 29, 2007 | 06:52 PM
Engine: 2.7L V6
Axle/Gears: 4.41
LOL. My 2.8 was the same way, except for the smoke thing (IIRC). I first registered her with 194,676 on the clock. The 2.8 was toast at 195, 239.7 miles (prev owner neglected the car entirely and I got stuck cleaning up the mess).
Anyways, there is not really any guarantee that if you were to go out and get another engine that it won't smoke on starts. What I would do is replace the RMS (since you have to replace the clutch anyways) and keep your oil pressure as high as you can until you can afford to have the heads repaired, or another engine.
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
